FULL RACE TWIN SCROLL 30R results and data
Old Jan 6, 2008 | 06:02 PM
  #226
Max Power's Avatar
Figured out the problem - send me that gt35
Did you do a boost leak test? It seems weird that unless you changed something significant (injectors, cam, intake/maf setup) that an idle problem would just pop up. I had something similar happen - had a minor boost leak after my clutch install on the licp. I don't think you have the vertical flow IC, but the LICP is kind of tough to get perfectly aligned. While the idle wasn't too different, it did hunt around a bit more. Under part throttle/low rpm it wasn't bad, but as the rpms went up it had a nasty bucking problem.
Old Jan 6, 2008 | 06:07 PM
  #227
EvoDan2004's Avatar
did a boost leak test. no boost leaks. i changed nothing but my turbo from a 30r .78 to a 35r 1.06
the car does not buck or anything like that. tomorrow im going to try to take some videos of idle and the surging issus.
Old Jan 6, 2008 | 06:10 PM
  #228
9sec9's Avatar
I'm fairly sure the 35 is going to flow more air at idle than the 30 or stocker. With more air, it stands to reason that you might need more fuel. You might also look at the airflow on the logger. Hope it's something that simple. Good luck.
Old Jan 6, 2008 | 07:15 PM
  #229
HaVoC RR's Avatar
put the 30 r back on and send ya motor out dan
Old Jan 6, 2008 | 07:19 PM
  #230
EvoDan2004's Avatar
HAHAHAHAH i just might.
Old Jan 8, 2008 | 06:40 AM
  #231
scherejs's Avatar
Figured out what the problem may be?
Old Jan 8, 2008 | 09:29 AM
  #232
EvoDan2004's Avatar
no sorry. i been very very sick since friday. so i have not touched the car. crap idk if its even still in my garage.
Old Jan 8, 2008 | 02:02 PM
  #233
Geoff Raicer's Avatar
Originally Posted by K Scorcz
Very nice work Evodan, can't wait for the 35r results. One question I have is how come you aren't using Full Race's Vertical Intercooler with this setup. Wouldn't it aid in performance over the hyperflow intercooler since it was designed for this application?
once the 35R testing is finished, we will test the VerticalFlow IC vs his current setup. We want to change as few variables as possible right now.
Originally Posted by blackevo110
another advantage of twin wastegates is boost management. and you can push a 30r past 30psi.
definately, 30R will make power to about 34/35 psi
sorry to hear i think i caught something too, its driving me crazy i have too much to do, I dont have time to be sick right now arrrgh
Old Jan 8, 2008 | 02:13 PM
  #234
EvoDan2004's Avatar
i took some vids of what the car is doing. ill post it up in a min.
Old Jan 9, 2008 | 09:07 AM
  #235
9sec9's Avatar
Hope you get better, the testing sometimes is enough to make you sick. Forge on brother, you have a public waiting on you. JK, get better first.
Old Jan 9, 2008 | 12:35 PM
  #236
EvoDan2004's Avatar
HAHA. WORKING ON IT SICK AS HELL BUT GOTTA GET ER DONE
Old Jan 9, 2008 | 12:46 PM
  #237
EvoDan2004's Avatar
ok here is a vid of how the car is surging. its very hard to make out as its hard to hold the camera on a steady shot. but you can kinda see how it hits full boost then surges and then go's away till redline.
the second clip of the vid is how the car idles from just doing the turbo swap. the only thing i mess with here is the bov. i left the bov alone when i put in the 35r. the car ran like poop. so i turned it all the way loose and u can see the car idles so much better. then i put it back to where it was on the 30r and the car gos nuts again.
Old Jan 9, 2008 | 12:48 PM
  #238
EvoDan2004's Avatar
ALSO
today i tryed playing with my cam settings. 30r was -2in 0ex. i put them to 0 0 and still have the surging issue.... now like i said it hits full boost holds holds then starts to surge then it clears up till redline ''when i let off''
Old Jan 9, 2008 | 12:50 PM
  #239
EvoDan2004's Avatar
to help u point where the surge is it seems to start around 4800ish and ends around 6kish.
Old Jan 9, 2008 | 12:53 PM
  #240
EvoDan2004's Avatar
1 more thing .lol
im running waste gate psi only. no mbc in the car. 22/23psi no knocking ether.
