Updated Forge Recirc Piston
I changed out my piston in my DV with the new style one from Forge. The new piston is the cylinder style below.
I went with the Blue spring and it seems to be working well.
Interestingly the car runs better but I think the green spring I had was bad. It is about 1/4 to 1/2" short in comparison to all the other springs I got in the kit. It may have just lost it's temper. When I tested it with the vacuum pump previously it opened at like 1/2 inHg.
With the new piston design the vacuum chamber requires more vaccum to actuate the piston. With the blue spring I have initial movement at 10 inHg and it is fully open at around 19 or 20. Remember stock was 14 intial so it is easier to open but will not leak like the stock valve.
I do have the valve in the way Forge recommended with the barb horizontal, not vertical. The noise that I was getting in the past with the valve installed this way and the old piston is gone.
So the piston does cure the odd squeak noise, which is good news.
George from Forge, if you read this please reply as to your plans to use the new design piston in the valves in the future. And thank you for your help with the piston.
Tim,
The green spring is slightly shorter and it is the softest. There is no color coordination to boost levels that can be equated to each vehicle. Variations from air filters, CAI, catback, turbo back, boost controller, etc....... will all have an effect as well as driver feedback. I would suggest that if anyone has an issue with the standard blue spring to put the yellow spring in. We have the blue spring in our VTA on the car here with no issues.
Completely stock I'd say Yellow is probably the best.
Once you start making any changes you will need to figure out what spring is best. Blue works really well for me right now but it's a little heavier then yellow and I am not stock, per se.
Yellow is just my guess though, I had green in before and it worked fine for me. You want the lightest you can go without leaking any boost when the boost is high. You can start with the blue and drive it and see how it drives.
damn it.. my bov isn't making any whoosh sound.. it kind of sounds like a muffled fart sound! i've tried all the springs and put it in with the hose verticle and horizontal... same results... i have the shims but haven't messed with them so far.. can somebody help me?
forge recirc (grooved type piston) and bauscher intake is the setup now...
Does anyone know for sure.....(Facts not Fiction) the order of the spring rate Highest to Lowest?
I got my tuning kit and it ahs a yellow spring, green spring and a red spring; Does this mean that I shoud have a blue spring in it?
Is the yellow spring Lighter than the blue?
I am thinking about going down a spring and maybee addinga shim or two to see if there is any difference.
I get a little bit of surge with high boost not all of the time though. Im thinking the spring might be just a little too heavy.
Thanks Guys,
Thanks Guys,
Originally posted by ForgeMotorsport
I think it was a while ago now. Time flies by very quickly. The newer piston design has a flat bottom vs. the concave bottom of the original.
Shaun@AWDMotorsports
EvoX 'For Sale' Engine Internals and Drivetrain
110
Dec 6, 2016 04:52 PM
Boost3dxEvO
20
Jun 6, 2015 08:50 AM
ilikeppie
Sep 17, 2012 03:39 PM
Clipse3GT
18
Dec 16, 2009 02:48 PM
