Buschur Racing tests the new HTA3076
Old Mar 24, 2008 | 11:28 PM
  #91
David Buschur's Avatar
flsilverevo,
It's hard to say what my RS would run on this turbo. My car ran 9.97 at 142 with 547 whp on our dyno. You can kind of guess from there that it should run 10.40's or so.
Old Mar 24, 2008 | 11:41 PM
  #92
sauce4u's Avatar
nice once again,this will be nice setup for the street and the track.For those of us who have the dd.most are looking for that in between point of the green and the hta35r,and this turbo will do the job.
Old Mar 25, 2008 | 10:12 AM
  #93
FL_SilverEvo8's Avatar
Originally Posted by davidbuschur
flsilverevo,
with the mods i have would i be alright with this turbo set up? i know i would have to get bigger injectors though.
Old Mar 25, 2008 | 02:25 PM
  #94
Ross W's Avatar
Nice results there David.
The HTA wheels look to be working very well
Great to see some objective testing.
Old Mar 25, 2008 | 05:03 PM
  #95
wizzo 8's Avatar
flsilverevo,
What about on 93?
Old Mar 25, 2008 | 07:19 PM
  #96
flsilverevo, yes, the turbo kit would work well with your mods. Of course, I would recommend a stand alone but that will open a new debate.
wizzo, I have no answer.
Old Mar 25, 2008 | 07:27 PM
  #97
wizzo 8's Avatar
Thanks David thats what I figured since its too new to know
Old Mar 26, 2008 | 03:54 PM
  #98
johnhwfd's Avatar
Just bought the new hta gt3076r kit with the cast manifold...
Will be installing and posting dyno results in a couple of weeks.
Will be on a stock block 2.0 , all other parts will be listed when posted.
Old Mar 26, 2008 | 04:13 PM
  #99
wizzo 8's Avatar
Cool cant wait
Old Mar 26, 2008 | 04:17 PM
  #100
bbbwrx's Avatar
Dave,
How would you think this turbo would perform on a 2.3L with a ported head with a 1.02 A/R? Or is the 1.02 A/R not recommended?
Old Mar 26, 2008 | 04:18 PM
  #101
OZrallyracer's Avatar
Johnhwfd... Did you buy the hta 3076 with the .63 a/r exhaust housing??? I'm really interested in the full spool rpm with that housing on that turbo. DB... What would be the tradeoffs between using the .82 and .63 a/r exhaust housings on the hta 3076? Which would you recommend?
Old Mar 26, 2008 | 07:14 PM
  #102
If he bought the cast manifold kit it comes with the FP turbine housing which is advertised as a .70 a/r. The 2.3 liter may work really good in a 1.02 housing with this turbo, it would be worth a try.
The difference in the .82 and .63 on this turbo will be a few hundred RPM quicker spool up.
Old Mar 26, 2008 | 10:01 PM
  #103
johnhwfd's Avatar
David B. which car was tested with the turbo the 8 or 9?
What size a/r was used on the test car?
Would a port and polish be possible on the cast manifold?
Old Mar 26, 2008 | 10:17 PM
  #104
bbbwrx's Avatar
From my understanding his RS is a 8 since it is a 2004
A/R used .82 as stated before
I am sure a gasket match port and polish would be beneficial but I am sure DB can shed more light on it.
Old Mar 27, 2008 | 06:52 AM
  #105
OK, thanks for buying the test turbo, we should be getting it out of here in the next day or two, we are waiting on the Tial 44 mm gates to come in.
The cast manifolds are matched to the cylinder head ports when you get them, DO NOT gasket match them to the factory exhaust manifold gasket.
