Evo Turbo Information
Old Dec 6, 2003 | 11:15 AM
  #46
DragonEvoVIII's Avatar
wrong thread
Originally posted by ShapeGSX
Chances are that he just revved the turbo too high, and/or the turbo was just abused.
I've seen 14B's (standard TD05H - inconnel) do the same thing. In fact, the one I saw shot out the car's tailpipe and was sitting on the track after his run.
this is the one i was laughing at
Old Dec 9, 2003 | 07:26 PM
  #47
YellowEvo8's Avatar
hey guys, i was wondering what the max psi of the evo 8 turbo is
Old Dec 9, 2003 | 08:02 PM
  #48
ShapeGSX's Avatar
I am running 26psi out of my Evo III turbo, which supposedly has the same compressor as the 8. I can't be sure, though.
Old Dec 12, 2003 | 09:21 PM
  #49
chiraoka's Avatar
ShapeGSX what is the weight of your 97 GSX ?
Carlos H.
Old Dec 13, 2003 | 04:40 AM
  #50
ShapeGSX's Avatar
3150lbs with the spare removed. That is how I race it.
Old Dec 13, 2003 | 09:27 AM
  #51
chiraoka's Avatar
that is about 1,428.82 kgs. ..... EVO 5 RS and EVO 6 RS (both came with a 16g6 and a 10.5T hotside) only weight 2,755.77 lbs. guess that is why they can get easily into the high 11s territory with minor mods.
Carlos H.
Old Dec 13, 2003 | 12:00 PM
  #52
alleggerita's Avatar
BTW, anybody know why went to the counterclockwise turbo on the version 4? Was it for gasflow, packaging???
Old Dec 13, 2003 | 01:28 PM
  #53
ShapeGSX's Avatar
With the engine on the other side of the engine bay, the exhaust gasses just want to flow in that direction. Plus it would have meant a big change to the engine bay if the turbo compressor were pointed at the other side.
Old Dec 15, 2003 | 10:44 PM
  #54
ItsStockOfficer's Avatar
I would like to hear this...explain please?
Old Dec 16, 2003 | 04:26 AM
  #55
ShapeGSX's Avatar
I think that the other reason I gave was probably the major factor.
However, take a look at this picture:
When the gasses hit the exhaust manifold, they have to make a 90 degree turn to enter the turbo. Hopefully this is a gradual turn in the manifold. You will notice in the picture that the exhaust will immediately start to turn more, in the same direction as the 90 degree turn (back towards the engine) as it enters the snail of the exhaust housing.
If they instead mounted a normal rotation turbo on the car, the exhaust would have to make a turn in the other direction as it enters the snail. This would probably decrease the efficiency of the system. I think that with all the tiny tweaks that Mitsu has done to the Evo's 16G turbo over the years, that this probably was a small part of their consideration.
Old Dec 16, 2003 | 05:59 AM
  #56
chuntington101's Avatar
Carlos H.
The RS’s where designed for competition use and have basic interiors and less sound deadening, that’s why they are lighter. This reduction of equipment leads to their slightly lower price as much of the equipment in the GSR’s are not wanted when you go rallying!
Old Dec 16, 2003 | 07:45 AM
  #57
chiraoka's Avatar
and the RS versions also came without the AYC rear diff , with the larger RS rear diff and a LSD, with bigger driveshafts, etc. .....
Carlos H.
Old Dec 28, 2003 | 01:59 AM
  #58
No...either way the exhaust gases would be going towards the block because if they mounted a normal rotation housing it would point towards the passenger side, or forse a huge heat shiled to cover the turbo that would probably hit the radiator....and the manifold turns are hardly gradual at all anyways.
Old Jan 6, 2004 | 03:46 PM
  #59
mifesto's Avatar
i always believed the U.S. evo 8 had titanium turbos
Old Jan 26, 2004 | 12:09 AM
  #60
-ND4SPD-'s Avatar
Question
What is the max horsepower that both the
TD05RA-15GK2-10.5T (GSR) / E6)
TD05HR-16G6-9.8T (GSR / USDM E8)
can support?
