ACD Help!
Old Aug 21, 2008 | 02:40 AM
piotr4net's Avatar
Originally Posted by karolis.bou
how acd works when its turned off?
the centerdiff works like open differential
Old Aug 21, 2008 | 02:56 AM
karolis.bou's Avatar
but power distributed at 50:50 (front rear ) ?
Old Aug 21, 2008 | 03:06 AM
piotr4net's Avatar
I think it always distribute 50:50, but ACD works like locker.
If You turn off ACD , You will not have only locker.
You can read more about it here https://www.evolutionm.net/forums/sh...d.php?t=175195
Old Jun 6, 2009 | 03:36 PM
MRevo8maniac's Avatar
Originally Posted by zeus1
used pump installed...problem solved..
Zeus1, I hope the replacement pump solves the problem. I had a pump fail and got it replaced under warranty. Maybe a year later the pump failed again but out of warranty. I have ignored it since I don't want to spend the money but if you have luck with the used one maybe I'll go that route. I have also read that since the ABS system is tied into the ACD the issue could actually be an ABS sensor but you'd think the car would tell you a sensor is shot. I'm gonna wait and see a bit longer.
Please let me know if your used pump fails.
Thanks
Old Jun 14, 2009 | 09:32 PM
hamflex's Avatar
Same problem today at a nasa event. have been tracking my car hard lately, came into a quick left hit the apex a bit then went to hit the brakes for a hard right and locked all four up. looked down and all acd light were on!
Hopefully something stupid iff not new pump here we go....
l2r99gst
Oct 11, 2018 10:23 AM
al3lwan
Jan 31, 2014 10:29 PM
AMSTuning.com
May 4, 2010 04:17 PM
Deathevn
Feb 21, 2010 08:06 PM
blackdemon
16
Nov 2, 2009 12:07 PM
