HTA35R First Impressions!!!!
Old Jun 1, 2008 | 11:10 AM
  #121
Bach's Avatar
TTP Engineering,
To make life easier for you here are a few conversions:
44C is around 112F
49C is around 120F
60C is around 140F
Old Jun 1, 2008 | 11:11 AM
  #122
Bach's Avatar
HAHAHA!!! Nice one Moosa
Old Jun 1, 2008 | 11:37 AM
  #123
SpeeDeviL's Avatar
Originally Posted by Bach
SpeeDevil,
Guess its going to be a hot summer lol
Have you had any problems with your car due to the heat?
No, everything is great, I have Buschur Stage 1-4 with out the injector's and the car feels awesome, thanks to Tamer.
Beat the crap out of a F430 last week from a dig , and it was around 38C-40C at night
Old Jun 1, 2008 | 12:01 PM
  #124
Bach's Avatar
Nice. Are there any dynos in kuwait?
Old Jun 2, 2008 | 12:33 AM
  #125
SpeeDeviL's Avatar
No, there use to be one, but it was closed because the owner didn't have enough money to keep it running.
There are dyno's but not AW dyno's
Old Jun 2, 2008 | 04:20 AM
  #126
dxbevo9's Avatar
we have plenty here in dubai..once i am fully tuned i will get a dyno run
Old Jun 2, 2008 | 06:40 AM
  #127
Bach's Avatar
Thats too bad, guess I would have to send the car to Dubai or Lebanon to get dynoed
Old Jun 2, 2008 | 06:41 AM
  #128
Bach's Avatar
Moosa,
When do you think you'll have your car on a dyno
Old Jun 2, 2008 | 10:23 PM
  #129
laxhero2's Avatar
what comes in the hta 35r kit and do you have a 2.0?
Old Jun 2, 2008 | 11:41 PM
  #130
fre's Avatar
fre
I still have a stock block and head and rev to 8500 all day long. Been doing so since about 40k on the car and now has 79k, so I wouldn't worry too much about that.
Old Jun 3, 2008 | 02:20 AM
  #131
SpeeDeviL's Avatar
what mod list you got, and do you use stock springs and retiners?
Old Jun 3, 2008 | 02:46 AM
  #132
dxbevo9's Avatar
go to buschurracing.com and start from there.
and yes i still have the stock short block
This kit includes everything you need to install this on a Evolution equipped with our front mount kit (other intercoolers do work some may require you to provide a lower intercooler pipe solution).
The kit includes: Ball Bearing HTA35R Turbocharger
BR Produced Cast Exhaust Manifold (from NI-Resist material)
TiAL 44mm External Wastegate
Stainless Steel O2 Housing
Replacement Low Profile Cooling Fan
Oil Feed Line
Oil Return Line
Misc. Fittings
Hardware
Gaskets Note: Our kit utilizes the factory water lines.
This kit has been proven capable of making consecutive 9second passes at the drag strip and 600+ whp on the Buschur Racing Mustang Dyno.
Old Jun 3, 2008 | 02:47 AM
  #133
dxbevo9's Avatar
wow thats great!! could you share how you are able to do this?
Old Jun 3, 2008 | 07:11 AM
  #134
fre's Avatar
fre
I am not sure what you are getting at, but I am physically able to do it because I have an AEM and I can set it to whatever I want. I do have head studs, but I don't think that would make a difference for revving, just max power. I have HKS 272 cams, but I am not sure if that makes a difference in the ability to rev either. I know springs and retainers are what I would need to push it further on the head side of things. I think a bottom end build might be necessary too, but again, I haven't researched it enough to know that the stock bottom end can't handle 9k+.
The stock head/block are just able to handle it. Have you heard of anybody floating valves at 8500rpm? I haven't really searched, all I can say is that my car can handle it. I probably have more than 100 1/4 mile passes revving to 8500 rpm as well.
Old Jun 3, 2008 | 07:46 AM
  #135
laxhero2's Avatar
was the kit a bolt? or did you have to buy more supporting parts? im about to purchase a kit also
