HTA35R First Impressions!!!!
Old Jun 3, 2008 | 12:15 PM
  #136
dxbevo9's Avatar
Originally Posted by fre
The stock head/block are just able to handle it. Have you heard of anybody floating valves at 8500rpm? I haven't really searched, all I can say is that my car can handle it. I probably have more than 100 1/4 mile passes revving to 8500 rpm as well.
i know someone who floated his stock valves reving to 8600 about 50/60 times..
anyways thanks for sharing...i am going to raise mine to 8300 now
quick questoin, do you shift at 8500 in every gear or just 4th?
Old Jun 3, 2008 | 12:18 PM
  #137
dxbevo9's Avatar
Originally Posted by laxhero2
was the kit a bolt? or did you have to buy more supporting parts? im about to purchase a kit also
it was a bolt on kit..but in order to run it you need bigger injectors, twin fuel pumps and a good azz intercooler ..all of which you can find at buschurracing.com
give them a call Jarrod will take care of you.
Old Jun 3, 2008 | 01:16 PM
  #138
Bach's Avatar
if your looking for 500whp all you really need (from the fuel side) is a walbro fuel pump and a Kenne Bell Boost-A-Pump and large injectors. If your looking for more than 500whp you will need the twin pumps.
This isn't from personal experience, its from Mellon's experience
https://www.evolutionm.net/forums/sh...d.php?t=313778
Old Jun 3, 2008 | 06:47 PM
  #139
laxhero2's Avatar
awesome review from mellon and good pics i think im close to sold on the kit
Old Jun 3, 2008 | 08:41 PM
  #140
dxbevo9's Avatar
i am not 100% sure about this, but i think mellon has already/intended to switch to the twin pump setup...which by the way works greatly well.
also, if you are intending to use only 93octane fuel, i would highly recommend using the buschur 4" Race Core intercooler, with better cooling the engine is much less prone to knock.
Old Jun 3, 2008 | 08:43 PM
  #141
importjake00's Avatar
how reliable is this for DD?
Old Jun 3, 2008 | 08:45 PM
  #142
dxbevo9's Avatar
believe me, if set up properly, along with other good supporting mods; this turbo is magic!!
it is a little laggy in comparison to the stock turbo...but think about it...what you loose down low, you gain 10 times as much up top!
BOTTOM LINE...IF I HAD TO DO IT ALL OVER AGAIN.....I WOULD!!!!!
Old Jun 3, 2008 | 08:52 PM
  #143
dxbevo9's Avatar
Its is very difficult to answer your question..because reliability depends on so many things other than the turbo kit...(i.e fuel, tune, boost, supporting mods and saftey mods etc.)
but IN MY OPINION, with the little lag this kit offers; it is like an ON/OFF switch...you are either hard and deep into boost or you are driving totally out of boost...which i think is reliable,
on my base tune, which was way off, i was running ~28psi and had 0 knock..i am now being tuned at ~30psi and getting the fine tune..i will throw it on the dyno when i am done.
cheers!
Old Jun 3, 2008 | 09:16 PM
  #144
fre's Avatar
fre
Yes, I shift at 8500 in every gear. I figure the higher the rpm the less lag between shifts.
BTW, what does 50/60 times mean? I revved my car to 8600 a few times, but I reduced it back to 8500, since the gain isn't worth the risk. Oh and what type of cams did the person that floated his valves have?
And just a bit of info. I am able to hit 140mph in 4th @ 8500rpm. Looks like the VIII and IX have the same final drive, but the gears are slightly different:
----VIII------IX
1--2.928---2.785
2--1.950---1.950
3--1.407---1.444
4--1.031---1.096
5--0.720---0.761
IX is geared taller in 1st, but seems to be geared shorter from 3-5.
Edit: Well for the 6 speed your ratios are:
1--2.909
2--1.944
3--1.434
4--1.100
5--0.868
6--0.693
Old Jun 3, 2008 | 09:31 PM
  #145
dxbevo9's Avatar
And just a bit of info. I am able to hit 140mph in 4th @ 8500rpm. Not sure if the IXs have different gear ratios.
not only do i have a IX...i am still running the stock 6-spd gear box
when it blows...i will have the shephard racing ultimate ratio gear box in no time..
Old Jun 3, 2008 | 11:28 PM
  #146
SpeeDeviL's Avatar
Can't wait to see the final results, good luck Moosa.
I'm coming your way soon, but my setup is abit different then your setup.
Old Jun 3, 2008 | 11:33 PM
  #147
dxbevo9's Avatar
thank you and goodluck with yours too....
whats your setup?
p.s. do you people like my new avatar?
Old Jun 3, 2008 | 11:44 PM
  #148
SpeeDeviL's Avatar
Thanks
My setup is the same as your's, but I'll be running the stock heads with stock springs and retiners, will install ARP head studs thats for sure, BR deluxe FMIC, M2 cosworth cams, HKS DLI 2, and now am saving money for the HTA35R tubular turbo kite.
It will take a while til I can get the turbo kite, but I got most of the stuff.
P.S. Your avatar rules.
Old Jun 4, 2008 | 12:17 AM
  #149
You should shift right around 7k, after that, your not really gaining anything. Im talking about for the 1/4 mile.
Old Jun 4, 2008 | 02:39 AM
  #150
dxbevo9's Avatar
Thanks
as an advice and out of personal experience i would suggest the following:
switch the Deluxe intercooler to the race core (especially that you are using only pump gas) which is much more efficient....search mellon's thread in the "service/parts review" forum as he did a test..
also i would highly recomend to get springs and retainers so you can rev to higher; and if you didnt get the cams already i would suggest you to use the M3 cams with this kind of turbo..believe me they scream up top!!!
