New CBRD build.... some cool stuff..
Old May 21, 2008 | 11:35 PM
  #106
DS-03evo's Avatar
I am using the .82 a/r on mine.
Old May 22, 2008 | 06:16 AM
  #107
tkklemann's Avatar
Originally Posted by 2000max
Quick disconnects are awesome. I use them on my car. It beats using ss line for vaccuum hoses. I'm pretty sure tractor trailers use the same type of fittings for air brakes.
www.Mcmaster.com is where I got mine from.
Yes they are, FMVSS and D.O.T. approved for use in Tractor Trailer Air Brake Systems. So, my guess is if they are good for 80,000lb truck brake systems at 100+ psi, they will be good for anything my car could possibly throw at them.
Old May 22, 2008 | 12:43 PM
  #108
CBRD's Avatar
Originally Posted by Talonboost
Man, if you do that, put a .63 a/r turbine housing on the HTA30R first! Your 50 trim hybrid is still using a .63 isn't it?
I would probably buy one of the hybrids if it clearly spooled faster than an HTA3076 w .63 a/r and made the same or more power on pump gas - and didn't surge!
Gary
Gary,
we really want to put a .82 hotside on the hybrid turbo, we think that will allow more power everywhere.
CB
Old May 22, 2008 | 07:09 PM
  #109
HaVoC RR's Avatar
stop talking about it and do it!. . . u seem to spend more time on the comp than working...gotta love ya chad
Old May 25, 2008 | 04:23 PM
  #110
Talonboost's Avatar
Originally Posted by CBRD
no, it is technically a "gt37" compressor wheel..... and not like when people say a "gt37" turbo...
its a slightly different version of a 3076R comp wheel......
Hmm, trying to keep this straight so I can tell your custom builds one from another.
The GT3776 compressor wheel is 76.2mm exducer and 52 trim. But it's not one of those?
The "regular" GT3076 available in the USA is 76.2mm exducer and 56 trim. It's not one of those either?
The HKS 3037 has a variety of 76.2mm exducer Garrett GT compressor wheels available, one is a 52 trim. Is it like that?
Thanks,
Gary
Old May 25, 2008 | 06:48 PM
  #111
DS-03evo's Avatar
Thanks,
Gary
Old May 25, 2008 | 11:45 PM
  #112
Talonboost's Avatar
Originally Posted by DS-03evo
I know for mine we are using 58lb compressor wheel, .82ar, stage 4 turbine.
The 58 lb/min wheel I believe would be the GT3782 wheel (82mm exducer).
Your 58 lb/min wheel by the way has a sneaky little compressor map (if it's the GT3782). At first glance it doesn't look like much. The GT3076 has higher max PR and almost the same max lb/min. But pick a likely max operating point. Say 3.25 PR and 50 lb/min. This is right on the max speed line of the GT3782 map. The GT3782 rated efficiency there is about 75%. Find the same point on the GT3076 map. Rated efficiency is only about 68%. That's a big difference!
The wheel that Chad says is 55lb/min has me bamboozled. I don't see where it came from.
Old May 27, 2008 | 12:36 PM
  #113
CBRD's Avatar
its not a 3782 wheel...
sorry, just saw the thread.
cb
CBRD
Nov 21, 2012 06:09 PM
CBRD
29
Dec 19, 2011 12:32 PM
CBRD
Feb 7, 2011 12:54 PM
CBRD
Oct 21, 2008 05:54 PM
CBRD
12
Apr 30, 2008 03:48 PM
