Ams Evo Cam Test
Old May 20, 2008 | 09:39 AM
  #241
turbo271's Avatar
So Martin, I know that this test is not about how a relativly stock evo, but what is your recommendation for a virtually stock evo? Which cams would you give the best marks to overall? (ex. HKS 272, HKS 280, FP4R, GCS3)
I'm talking about Daily Drivability & Great power for just a drop-in.
Old May 20, 2008 | 09:51 AM
  #242
PsychDr. HN$'s Avatar
for me it kinda come down to HKS 272 or BC 280's drop right in. GSC S2's make more power but REQUIRE springs and retainers. I prolly wont go any larer than a HTA 30R but more than likely I will do a HTA FP Green. Even if i did BC's which are the least expensive and powerful of the cams testing, I do realize than ANY cam would be better than the STOCKER.
Old May 20, 2008 | 10:14 AM
  #243
Martin@AMS's Avatar
GSC S3's are up
Old May 20, 2008 | 10:18 AM
  #244
Martin@AMS's Avatar
You have to be carefull with a stock turbo, too big of an exhaust cam with an early opening event will bleed off too much pressure on the combustion stroke. I would stay with something mild and possibly different duration on the intake & exhaust cam. This is something I'll be experimenting with. HKS 272 are still great, possibly S1's even though I didn't test them, FP4R's.
Old May 20, 2008 | 10:21 AM
  #245
Martin@AMS's Avatar
BC 280's have a rough idle and drive ability for the power gains. I ran the BC cams straight at zero on the cam gears to see how they would perform not being degreed in. The power was way down and they really idled and drove poorly. I would recommend the S2's, Kelford 272's or the FP5R's at that point.
Old May 20, 2008 | 10:28 AM
  #246
rEVoLed's Avatar
How much worse is the GSC3 in terms of drivablity issues and you mention choppier idle? How bad is it? I'm looking to upgrade from the HKS 272 when I get my headwork done... bottom end is built already running on a 35r.
Old May 20, 2008 | 10:43 AM
  #247
sabastian458's Avatar
I agree with this. The BC-280's have a agressive idle, driveablity is moderate. Only every once and awhile is there any hicups while driving. 2 simialarly modified stock turbo 8's, 1 with older GSC 272's and My Evo with BC-280's, the 280's pulled more in each gear change. I love them, but I wish they were more precise with the manufacturing.
Old May 20, 2008 | 11:32 AM
  #248
turbo271's Avatar
I'm in the same boat as you. I will eventuall graduate up to either the FR Green or FR GT30R. I just want something I know is going to tag-team well with those turbos, but still be good with the stocker.
Old May 20, 2008 | 11:35 AM
  #249
turbo271's Avatar
By the way the S3's look fantastic, but I'm guessing it wouldn't work so well on a stock head.
Old May 20, 2008 | 11:40 AM
  #250
Paul Nelson's Avatar
Very nice power band. I run them
Old May 20, 2008 | 11:46 AM
  #251
evovin's Avatar
I know AMS tested the S3 with GT35 but GSC said they dont suggest this cams on smaller that 42R.....
Will this be fine with my HTA37R?
What is the difference between the solid lifter against hydraulic on performance wise?
Old May 20, 2008 | 02:14 PM
  #252
Ph3n1x's Avatar
Good stuff with the S3's
Old May 20, 2008 | 02:38 PM
  #253
It seems that the BC 280's had about the same power down low as the stockers and performed fairly well, had a tad bit more power earlier the some of the others.
Heck even if you had to redegree the cams some, it seems they are worth the $$
Old May 20, 2008 | 03:03 PM
  #254
wshihdnevo's Avatar
Thats why AMS did this test...? Looks like they would work fine.
Old May 20, 2008 | 03:05 PM
  #255
Colt4g63's Avatar
Are we going to see JUN 272s?
