Ams Evo Cam Test
Old May 13, 2008 | 03:25 PM
  #181
Turbo Kyle's Avatar
Going to buy the magazine
EDIT: **** on Wal-Mart
Old May 13, 2008 | 03:37 PM
  #182
Evo8luva's Avatar
I am going crazy waiting to see the GSC cam results!!
awsome thread, good job AMS!
Old May 13, 2008 | 03:42 PM
  #183
evo_08's Avatar
this thread is worst torture then waterboarding.
Old May 13, 2008 | 03:52 PM
  #184
Martin@AMS's Avatar
Originally Posted by alan678
Gotcha....but that doesn't mean that they CAN'T be tested.....hopefully one day
With the Evo VIII Cosworth M2's (which have a 280 duration and an 11.0mm lift on both cams) the results should be pretty good in comparison since similar cams are used by most Evo IX owners....lets get the VIII owners some similar 'dyno proven' results
Evo VIII Cosworth M2 Spec sheet...
http://www.cosworth.com/uploads/1147891526.pdf
One thing to remember is that advertised duration is pretty much worthless when comparing cams. HKS 272, JUN 272, CRANE 272 are completely different from each other and make very different power. You really have to look at .050" lift duration numbers to get a better idea of what the cams are going to do.
Old May 13, 2008 | 05:11 PM
  #185
crcain's Avatar
Are you going to release the cam gear settings you used to get the cams to the manufacturer spec?
Old May 13, 2008 | 05:16 PM
  #186
demartinoink's Avatar
that made picking a cam easy! thanks!
Old May 13, 2008 | 05:21 PM
  #187
wshihdnevo's Avatar
^the test isnt even done?
Old May 13, 2008 | 05:22 PM
  #188
MR_EVO21's Avatar
I noticed that you guys are trying to degree in the cams to the factory centerlines; however why don't you guys just install them straight up and run them out of the box?? It would make more sense to see the capablities of each cam as they were designed from the manufacturer. Just a thought
Old May 13, 2008 | 05:44 PM
  #189
joedr's Avatar
EvoM Moderator
Martin,
Any chance that the graphs can be plotted using RPM instead of car speed?
BTW, I appreciate the time and effort of doing this type of test! Good job!
Old May 13, 2008 | 05:56 PM
  #190
JC evo1's Avatar
im pretty sure thats what they have done, set them up per each manufacturer's specs, then played aruond with cam gear settings, correct me if im wrong.
Old May 13, 2008 | 06:30 PM
  #191
Cirrusly Evolvd's Avatar
If I remember correctly the first article said that each cam is milled slightly different and may not even match the intended specs. Hence all the expensive testing to find it's centerline and correctly degree each cam to match the specs of the manufacturer. Two sets of cams from the same company can have the same duration and lift but be a half a degree off or more from each other.
Old May 13, 2008 | 06:41 PM
  #192
joedr's Avatar
EvoM Moderator
Correct! All of the tolerances (Cams, cam gears, timing belt) can throw the cam off from the manufacturer intended 0. Therefore, AMS dialed them to their true 0 considering Piston 1 at TDC... regardless of what the cam gears are finally dialed.
Old May 14, 2008 | 06:58 AM
  #193
GTVEVO's Avatar
Subscribed, awaiting GSC S2 testing.
Old May 14, 2008 | 07:06 AM
  #194
slicedbreadno2's Avatar
Nice results on the HKS 272's
Old May 14, 2008 | 07:33 AM
  #195
AutoMotoSports's Avatar
sorry for this layover guys. Martin didn't realize that he was going to take a much needed vacation in the middle of this. I think he was due as he has not gone on one for the better part of 3-4 years LOL.
He will be back on Thursday and he will make up for lost time. Sorry again and thank you very much for your patience.
Eric
