Ams Evo Cam Test
Old May 15, 2008 | 10:40 AM
  #196
GrocMax's Avatar
Someone needs to fly up and do some more BBQ methinks.
I'll trade a CD for some pork loin
From observations while there, and in my opinion I think Martin's car is not typical, it makes good top end at low boost and is a little light on the bottom, so take that into consideration when trying to decide what will work for you.
What it all will boil down to is that cams with similar valve motion specs will perform about the same on the same test bed, the trends will become clear.
What works optimally on one car will not on another. You will notice shops will prefer one grind over another, because they saw better results on their combos. This does not mean their preferred grind is the only one that works. Hell, look at SBC's- must be at least 1000 grinds for std geometry std core diameter flat tappets. There is a valid reason for this. Those of you wanting to get optimal results on your own setup are going to have to experiment a little. Maybe someone ought to start a 'cam trader', it would reduce end-user's R&D costs.
It would have been interesting to have had a calibrated MAF on the car and do some math.
Y'all have NO ****ING IDEA how much time and money this cost AMS, every one of you who takes info away from the published results and uses it needs to go buy something from them. You need to support the people who support you, and not just shop price at www.dormroom.com drop-ship places.
Scott @ FP
Old May 15, 2008 | 11:16 AM
  #197
sabastian458's Avatar
I have spent a few thousand $$$ with them already
Old May 15, 2008 | 11:19 AM
  #198
ok so he has been back for 1/2 day. Is he not done yet?
:P Good job on the test!
Old May 15, 2008 | 12:07 PM
  #199
9sec9's Avatar
Scott @ FP
Scott, thanks for a little insight. I am anxiously awaiting the final results. We currently run the JUN 272's, but anticipate a turbo upgrade and will certainly be looking at a possible cam change. This test will help in that making that decision.
Old May 15, 2008 | 12:08 PM
  #200
Hey, I might be lookin for a set of JUN's
Old May 15, 2008 | 12:20 PM
  #201
Nez136's Avatar
I will be patient for these guys, im sure its always a task throwing a test like this together between all the work they already have. I have had my HKS 272's in for years now and I am so excited to see what these test results bring. The only wish i have is to test the BF 272's against the rest only b/c i have only seen graphs from Buschur built cars and I have no idea on the specs of these cams. I want to see what they do with this current setup.
Overall these test results will help my final decision on my next upgrade in a HUGE way, Thanks again AMS.
Old May 15, 2008 | 12:22 PM
  #202
AutoMotoSports's Avatar
lol I have been nagging him all morning about it, hes obviously very busy from not being here for a few days but he will get something up today.
Eric
  #203
j14mp's Avatar
haha i bought some used hks 272's off u guys.. are these them? are they famous now? lol
Old May 15, 2008 | 12:26 PM
  #204
I am super anxious for the Brian Crower 280's. I have always wanted to see what a graph of them looks like.
Old May 16, 2008 | 08:50 AM
  #205
Martin@AMS's Avatar
update with Brian Crower Stage 3's (280)
Old May 16, 2008 | 08:53 AM
  #206
Nez136's Avatar
And we are back in action
Old May 16, 2008 | 09:04 AM
  #207
gt42r's Avatar
I think today you should post about 3 results cause we waited all that days!
Old May 16, 2008 | 09:14 AM
  #208
Martin@AMS's Avatar
Scott @ FP
Thanks Scott! Because of you a bought a smoker and now i smell like a forest fire on weekends. BBQ ribs never tasted so good!
Very good point you make and readers need to know that throwing a set of Tomei 280's or FP5R's on a stock turbo won't net the same results as on my setup. I did a little testing and if you go too big on the exhaust side with a stock turbo you'll kill spool up and bottom end power without any real gains.
We put in some FP5R's on a evo 9 - 2.3RR build and they worked really nice, picked up a decent amount over the previous cams. Too bad they're on back order, I got a few peep's waiting on them.
Old May 16, 2008 | 09:41 AM
  #209
crcain's Avatar
Cam gear settings used!!!
Are you reading this thread AMS?
Old May 16, 2008 | 10:08 AM
  #210
Martin@AMS's Avatar
Are you yelling at me?
My settings on the BC STG 3's was 4 degrees retarded on the exhaust and 2 degrees advanced on the intake to be at 0/0. All other cams I tested where withing 1 degree.
You should make fixtures and a custom tip to hold a dial indicator on the retainer, get a degree wheel on the crank, figure out cam specs, find CL and adjust the cams. Not to mention the cams specs on the BC cams card are not correct, so if you go off that you'll be off anyways. You have to find the valve events on your own, figure out CL and then interpret where they wanted it. I have hours and hours into this and to be honest, since your setup can be different than mine (different deck height, head thickness, cam gears, ect), you really should degree it on your car. If the cams I measured were that far off, who knows if other batches are the different.
