Ams Evo Cam Test
Old Feb 10, 2016 | 11:28 AM
  #826
EvoAs$hole's Avatar
Can somone please send me the graphs?
Old Feb 10, 2016 | 02:20 PM
  #827
Ted B's Avatar
Here are the test results saved as a pdf file with my cam spec notes included. Enjoy.
File Type: pdf
Old Feb 10, 2016 | 02:53 PM
  #828
ZanarkO's Avatar
Originally Posted by kikiturbo
this depends on the overall package because the combo of cams, turbo, intake and IC piping will sometimes produce some weird pulses in the intake that will mess up the MAF.
For the record, I installed S2 on evo 9 with hks turbo and my own IC piping and IC + ETS steel intake and on MAF it was impossible to get to idle and on small loads it was real bad... fueling was all over the place... even with getting mivec to do -0.6 deg intake cam timing
We then replaced the ETS intake with stock, and then it was quite ok apart from idle itself which was ok when tuned for 1100 RPM and a bit richer AFR but it always had this idle drop from time to time... sometimes almost shutting off..
When we switched the car to SD idle is perfect.. 950 RPM and 14.7 AFR.. and works fine even with a couple of deg of intake cam advance on idle and ETS intake.. ..
Sorry to bump this from ages ago but this is the EXACT PROBLEM I had with S2s in my evo ix. I had the metal ETS intake with a MAF and the car had very strange partial throttle and drivability issues. It felt horrible. Switched to speed density and the car drives 100% now. But my idle is a little muffed pretty sure my coilpacks are going out at 99k miles.
Old Feb 10, 2016 | 03:09 PM
  #829
EvoAs$hole's Avatar
Thank you so much
Old Feb 14, 2016 | 06:55 PM
  #830
High_PSI's Avatar
WOW those Kelfords are amazing!!! Best overall!
Old Feb 14, 2016 | 08:37 PM
  #831
Erik@MIL.SPEC's Avatar
That's a way old test. I think the GSC S2's are the new standard. On stroker motors, the R2's are even better.
Old Feb 15, 2016 | 12:52 AM
  #832
ZanarkO's Avatar
S2s in an EVO IX are amazing. And idle like stock.
Old Feb 15, 2016 | 11:18 AM
  #833
High_PSI's Avatar
I have them, not QUITE stock, my S1's are stock idle. Very good however certainly 100% street-able.
Old Feb 15, 2016 | 11:43 AM
  #834
tsitalon1's Avatar
I still have the Kelfords.
Thought about switching to the S2's, not sure the gains would be with the expense and work though..especially as I rarely go above 7k.
Old Feb 16, 2016 | 05:40 PM
  #835
ZanarkO's Avatar
idk bud I bumped my idle timing up some and went speed density and it sounds like stock
Old Oct 6, 2016 | 02:57 AM
  #836
daniel5115's Avatar
suscribed
Old Oct 6, 2016 | 09:11 AM
  #837
kikiturbo's Avatar
yup, I did a E9 on S2 cams and after we went to SD it is stock idle... 950 RPM and 14.7 AFR..
Chris@nolimitmotors
EvoX 'For Sale' Engine Internals and Drivetrain
288
Jan 26, 2017 08:34 AM
Chris@nolimitmotors
Evo 'For Sale' Engine Internals and Drivetrain
400
Jan 26, 2017 08:25 AM
Ganabi
18
Oct 1, 2016 04:27 PM
adcgn45
119
May 18, 2016 04:51 AM
TheBoz
Mar 7, 2016 07:54 AM
