Ams Evo Cam Test
Old Jun 10, 2015 | 11:38 AM
  #811
ReaperX's Avatar
Originally Posted by High_PSI
Best for the Street are Basically GSC S1's or GSC S2's. Take your pick. S1's for a street car and smaller turbo.
I wouldn't even recommend someone to go with anything smaller than an S2. You can tune it to have great street manners and it doesn't lose anytime in spooling a stock turbo.
Old Jun 10, 2015 | 06:16 PM
  #812
High_PSI's Avatar
I disagree, a stock turbo or a green can really use S1's for that road race punch. S2's would add some lag to that.
Old Jun 10, 2015 | 06:24 PM
  #813
1SlowRS's Avatar
What are cosworth m2 cam like as for gains and are they worth getting?
Old Jun 10, 2015 | 07:05 PM
  #814
ReaperX's Avatar
S2's and a stock IX turbo was full boost, 25psi, at 3250 in 4th gear and 3500 in 3rd gear on a dynojet when I ran that setup last year. Same as when I was on stock cams. I have the logs with the S2's if you don't believe me. Not trying to start an argument, but S1's shouldn't even be in the equation with how well the S2's and a good tune spool the turbo.
Old Jun 10, 2015 | 07:19 PM
  #815
Bhsj13's Avatar
i have kelford 272's lost like 100rpm worth of spool but is anyone going to feel the "loss in spool" i dont think so. still hits full boost well under 4k.
Old Jun 10, 2015 | 09:38 PM
  #816
Nimpoc's Avatar
Ams Evo Cam Test
ReaperX & Bhs, are you both in Evo8's? If so what's your idle RPM and how's the idle chop with a good tune? Lastly SD or MAF?
I've got a set of TX-272's to replace my TX-264's and have been debating if the top end gains will be worth the great daily drivability. The 264's were all gain over stock.
Also trying to figure out if I could adjust cam timing enough on the 272 to smooth out the idle so I could pass smog. Not stoked on cam swapping just for that.
Old Jun 10, 2015 | 11:43 PM
  #817
kikiturbo's Avatar
I have tuned stock cars, kelford 264 + stock turbo and S2 + HKS, on a 9, and there is no disadvantage when going to S2. Spool is great.
We did have MAF related problems on idle, but we cured that by going for SD. The S2 equipped car now idles at 950 rpm and 14.7 AFR with no issues whatsoever..
Old Jun 11, 2015 | 09:48 AM
  #818
High_PSI's Avatar
They are good, I believe that the GSC S2 is slightly better. This test shows it.
Old Jun 11, 2015 | 09:57 AM
  #819
ReaperX's Avatar
Evo 8. Idle is set at 1000 rpm, MAF, 15* timing, closed loop. It lopes a bit but doesn't chop real hard. It'll idle even better with 12* timing if I force it open loop and run a 13.5 to 13.9 afr @ 900 rpm.
Old Oct 25, 2015 | 08:35 PM
  #820
740 Turbo Brick's Avatar
Anyway to save these links? This is a great thread it would be a shame to lose all that work.
Old Oct 26, 2015 | 05:17 AM
  #821
Ted B's Avatar
I've saved all information and graphs relative to the test, so they're not lost.
Old Oct 26, 2015 | 07:55 AM
  #822
spoolin d dub's Avatar
This was a awesome cam test for its time. It does show how different cams would perform on this car. The issue is it shows no real comparable data to apply to other setups because All setups are different. Its just to many variables. Dsport's cam test has more accurate data. The cams they tested compare the real cam specs lift and duration at the cam across the board (since most cam companies don't use the same measurement procedure for the specs). Now you can do a apples to apples comparison then factor in the other variables.
Old Oct 27, 2015 | 12:36 AM
  #823
Cool, so there is hope to have this thread restored in the future.
Old Oct 27, 2015 | 05:46 AM
  #824
Ted B's Avatar
I'll see what I can do to repost the data when I get a little time.
Old Dec 1, 2015 | 08:34 PM
  #825
Boosted Tuning's Avatar
Please report or email me the data please, Ted.
Email in sig.
