Ams Evo Cam Test
Old May 7, 2008 | 03:54 PM
  #91
spdracr's Avatar
nice job AMS great info. subscribed
Old May 7, 2008 | 05:18 PM
  #92
Ludikraut's Avatar
Originally Posted by evovin
Are you going to post the cam gear settings too on each cams?
Originally Posted by Martin@AMS
Every cam was installed straight up...
Looks like they were installed at 0/0, not considering the amount of advance/retard that had to be dialed in to get them to exactly 0/0. AFAIK, the amount that the cams had to be degreed for this test would not readily translate to your or my engines.
l8r)
Old May 7, 2008 | 07:00 PM
  #93
1slowevo's Avatar
Originally Posted by Jasil
Very sick power!! All I need to know is does the drag car run Tomei now?
+1
Old May 7, 2008 | 07:13 PM
  #94
Aby@MIL.SPEC's Avatar
Awesome Test AMS
Cosworth did not want to be part of the test unfortunately, I really wanted to see what they would do.
i can pull my cosi m2's out of my car & send them to you priority mail if you like
no $hit- just say the word & consider them there!....however i may want to try your tomei 280's on 91 octane for $hits & grins
Old May 7, 2008 | 07:39 PM
  #95
EVOlutionary's Avatar
l8r)
Your post is a little misleading. I assume they were not set at 0/0. I think they were set at whatever yielded "straight up". This info would be nice to have. Assuming each manufacturer has tight tolerances in cam to cam manufacturing why would saying X cam was set at -1/+2 (or whatever) to yield "straight up".
Maybe I am missing something or have a misunderstanding of cam timing. If so, please share to expand my knowlege as well as that of the EVO community.
EVOlutionary
Old May 7, 2008 | 07:53 PM
  #96
Ted B's Avatar
And a noteworthy point for those who tend to overlook the details . . .
Keep in mind that Martin is NOT using a stock head. A stock head chokes above ~10.5mm lift, and cannot respond to the extra lift of cams like Tomei 280. The cams can only work as well as the head.
Old May 7, 2008 | 08:13 PM
  #97
Cirrusly Evolvd's Avatar
Can't wait to see what you guys came up with in the GSC S2's....care to share your findings as far as cam timing? I have the AMS head and S2's so I could use a little help
Old May 7, 2008 | 09:45 PM
  #98
1badgsex's Avatar
why no jun cams in this test... i just bought a set, waiting to be delivered
Old May 7, 2008 | 09:55 PM
  #99
Colt4g63's Avatar
Finally the test!! Im in.
Old May 7, 2008 | 11:54 PM
  #100
Sean@Iveytune's Avatar
Very good and credible testing by the BEST!!!!
Sean
Old May 8, 2008 | 04:55 AM
  #101
ShaunSG's Avatar
What do you mean by choke? Moving into higher L/Ds is not equal to choke.
Old May 8, 2008 | 04:57 AM
  #102
MR Turco's Avatar
I think he means the head cannot efficiently move the air out with that much lift. It will start to cause back pressure in the cylinders.
Old May 8, 2008 | 07:10 AM
  #103
crcain's Avatar
EVOlutionary
I like your guys points here.
Martin can you let us know how many cam degrees you typicall needed to adjust to get each cam to the specs of the manufacturer? This would be interesting as an example of the quality control of the cam.
Old May 8, 2008 | 07:14 AM
  #104
crcain's Avatar
Some cams exhibit quite different centerlines so it was interesting to see how they performed.
Sorry I'm being dumb and don't understand this. Do you mean each manufacturer had different specs for where the centerline should be in terms of crank degrees?
Would love for you to answer the couple questions I just asked and also talk about any other observations you had in terms of the dialing in the cams. Did you try advancing the Tomei intake cam? Would that maybe give a bit better spool?
Old May 8, 2008 | 07:20 AM
  #105
Martin@AMS's Avatar
Exactly That's why I like using Jun 272's on a stock head with valvesprings retainers, they don't have big lift but they have a lot of area under the lift curve and good opening and closing ramps. Advertised duration is 272 on the Jun's but the duration at .050" is 225 on the intake and 226 on the exhaust. The HKS 272 (advertised duration) only have 208 on the intake and 206 on the exhaust at .050" The GSC S2's have 217 on intake and exhaust at .050"
