Evo 7 Injectors (Impedance Question)
Old May 13, 2008 | 01:16 PM
clip14's Avatar
Hi, Sorry for the newbie question here:
I am currently adapting an evo 7 ecu to run on a different mitsubishi (non-4g63) and need some clarification on the injector setup to ensure that I don't burn out my evo 7 ecu.
Currently the engine in my car is running high impedance injectors with no resistor pack.
I am planning to run the evo 7 injectors and evo 7 ecu.
Does the stock evo 7 use a resistor pack?
Old May 23, 2008 | 05:00 PM
clip14's Avatar
can anyone help?
Old May 24, 2008 | 12:13 AM
mrfred's Avatar
The Evo uses a saturated style injector driver system, so you'll need a resistor pack when using the Evo 7 ECU and injectors. Or, if you've got a few extra $$$, the FJO peak & hold injector driver kit might be a nice addition.
Old May 24, 2008 | 12:31 AM
clip14's Avatar
Hi, thanks heaps for the reply.
Do you know where I can find the exact specifications of the resistors I need to wire up?
Old May 24, 2008 | 12:38 AM
mrfred's Avatar
Probably the same as the Evo 8/9. Both use a 6.0 ohm resistor. Most vehicles that use this hybrid system with a saturated driver and low impedance injector use a resistor that's around 6-7 ohms. Expect up to about 1.5 amps of current at 14 V. The resistor needs to be able to handle the power. You're best bet is to get an OEM Evo 7/8/9 resistor pack. They are an individual part that can be bought.
bbyevo8u
15
Nov 2, 2016 06:04 PM
Raceghost
For Sale - Part Outs
Aug 22, 2016 09:32 AM
TurboTravis
Sep 3, 2011 01:23 PM
Street gear
Feb 28, 2010 04:33 AM
schang_18
Lancer Engine Management / Tuning Forums
Apr 19, 2008 04:10 PM
