Electric water pump
Old Jun 25, 2009 | 01:19 PM
Johnboy1065's Avatar
Originally Posted by S2kracka
Just buy a remanufactured pump for under $100 from a parts store and save yourself the time, expense, and hassle (unless you're trying to build a maxed out actual track car).
I'm considering every option
that would def be the cheaper route but hell, when you mod a car to the point to where you are considering an electric water pump then you've prolly already spent a TON on your car lol
the main thing I'd be concerned with is how well it cools. Because I do drive my car a lot on the street, even though it is not my daily driver anymore......I love the car too much to just let it sit all the time
Old Jun 25, 2009 | 01:25 PM
evo_glasses's Avatar
If it ain't broke don't fix it... lol... Let us know what you do... I'd really like to see what goes into a project like that myself...
Old Jun 25, 2009 | 02:08 PM
PATRICK B.'s Avatar
Just like Johnboy it seems mine took a crap on me after a 10sec pass in the pits.
Now i'm really skeptical about using a re-man piece is it just me or does an oem mitsu part sound better?
I'm more concerned about the price of an electric pump and the fact that i do still like to have the ac/ps ........i just don't want to be changing pumps often so i'd consider an electric in that instance.
Have you guys experienced a lot of water pump failures or do they seem to hold up?
Most searched threads on water pumps are from years ago.....
Old Jun 26, 2009 | 04:45 AM
ZyBeR's Avatar
I'm using an electrical water pump in the zEvo. I CNC milled a custom plate so I could remove the stock pump.
More infor here: http://zevo.se/blog/?p=687
Old Jun 26, 2009 | 07:05 AM
andrewzaragoza's Avatar
nice fabrication. could you provide more information about your electric water pump setup like the pump you used, mounting location, etc.
Old Jun 26, 2009 | 07:49 AM
ZyBeR's Avatar
You can find more info on my blog http://zevo.se
Old Jun 26, 2009 | 09:27 AM
Zyber, where do you place the electric water pump in the coolant system?
thanks
Old Jun 28, 2009 | 04:16 AM
ZyBeR's Avatar
I'll try to fix some photos for you later on, but I have attached to the bottom outlet of the radiator, I've also removed the thermostat.
I've done this to free up some extra hp on top and also to maximize the cooling as I'm using an Laminova heat exchanger instead of an oil cooler.
rong.
18
Aug 30, 2018 11:49 AM
03whitegsr
47
May 29, 2018 11:11 PM
DrivenFab
Dec 3, 2015 01:39 AM
yenny
Aug 27, 2012 05:41 PM
dsmfan95
15
Jan 27, 2010 02:39 PM
