QuarterMaster's Lightweight Driveshaft Replacement
I, like alot of peeps on this thread are on a real estate guilt trip w/ market so buy-able also. So hard to part w 550.00 right now but maybe soon.
The Evo is gonna be crinasty one day...thats what I keep telling myself. Seeing cool stuff like this come out just makes me wanna keep it in the garage more and get paid off.
I thought 3k was the only solution....I always knew it would be a great mod at the scales and for driveability
.....also gotta get the aluminum rear diff carrier from Buscher
95% of it atleast is rotating mass.. not much you can remove that doesnt rotate by going to 2 shafts from 3.. for the price this DS is 100% worth it IMO..
yes sir i did. i was told around one week. what im doing is im waiting for it to come into stock. then there calling me and im sending my DS in. then there sending me the mean shaft i mean devo drive shaft that way i only pay the 550.00....... but im paid and just waiting for a ringy ding now
If anything you may gain a little more "feedback" as the buffer provided by the heavier stock components is reduced.
This is not accurate. Weight is a factor but the diameter at which the weight is removed or added is more critical. One pound removed from the outside of a wheel will affect the moment of inertia a LOT more than one pound removed from the center of a wheel.
A drive shaft of the same weight but larger in diameter will have a larger moment of inertia and will essentially rob power. Enough difference in diameter, and even a lighter drive shaft that is larger in diameter can sap more power.
I'm wondering whether removing the center joint has an adverse affect on the operating angles of the two remaining joints. Bad angles can lead to accelerated carrier wear and vehicle vibration.
Bravo! And +1 for you too. The notion that our cars will readily take to anything some tuner (no disrespect to anyone mentioned in this thread) or you yourself can fabricate is a risky one. Glad someone said it.
alleggerita
26
Sep 7, 2015 01:34 PM
antilag_200
17
Jul 31, 2013 05:12 AM
neonglh
Feb 5, 2011 08:10 AM
2004, devo, drive, driveshaft, dyno, evo, lancer, light, lightweight, master, mod, quarter, quartermaster, replacement, shaft, weight
