QuarterMaster's Lightweight Driveshaft Replacement
Old Jun 17, 2008 | 11:00 AM
  #46
iamdace's Avatar
had mine for two years now.. daily driven with multiple hpde's ...no issues.
  #47
EVO8LTW's Avatar
Originally Posted by PURE EVIL 8
3) it is 14.5lbs in weight savings over the stock driveshaft
Is all of that the savings in the shaft itself, or does that include the savings attributable to the non-rotating parts associated with removing a joint?
Old Jun 17, 2008 | 11:19 AM
  #48
11secEVO7's Avatar
to answer some questions:
1) The driveshaft is chromoly tubing and we need your stock driveshaft because it reuses the stock joints and yolk
2) We have tested this driveshaft out for YEARS and have never had a single one break on us on different cars. We have run them on evo's for over 1 1/2 years now with the same results. Two evos that have run it are over 900whp so we have taken the driveshaft to that limit so far.....
will it work on my evo 7...
JDM evo 7 gsr w/ AYC
Old Jun 17, 2008 | 11:33 AM
  #49
EvoDan2004's Avatar
ok i get that its 14.5 lbs lighter. but is that also 14.5 rotational mass lighter????
what i mean is lets sat the stock drive shaft weighs 40lbs. but 30 of it is the rotating shaft. your Drive shaft could be 14.5 lbs lighter but only 7.5lbs of it is actual rotational savings. so what is the actual rotational savings over stock.
Old Jun 17, 2008 | 06:13 PM
  #50
EvoDan2004's Avatar
Bump. I'm highly interested
Old Jun 17, 2008 | 06:19 PM
  #51
w evo's Avatar
nice...i was just reading about devo tuning's drive shaft in another thread the other day..does it remove a carrier bearing?
Old Jun 17, 2008 | 06:28 PM
  #52
EvoDan2004's Avatar
Thers is nice to but the price and the actual rotational weight difference is not worth it at all. Imho
Old Jun 17, 2008 | 06:38 PM
  #53
Blue Evo 8's Avatar
Losing the static weight is good, but losing rotational weight is better I would think..... need more info.
Old Jun 17, 2008 | 06:48 PM
  #54
EvoDan2004's Avatar
Blue evo 8
Same thing I'm saying.. I almost bought the devo one but then saw the actual rotational savings and the price. So now my eyes are on this one.
Old Jun 17, 2008 | 06:52 PM
  #55
newMRevoNyne's Avatar
Read Mitch's original post, you are loosing nearly 15 lbs from the driveshaft, that means actual rotational weight, 15 lbs from a device that rotates! Call up Devo and speak to them, they can explain where you are gaining the benefits.
Old Jun 17, 2008 | 06:56 PM
  #56
dryad001's Avatar
Looks like Im heading to Chicago in 3 weeks to pick one up.
Old Jun 17, 2008 | 06:59 PM
  #57
EvoDan2004's Avatar
NewMRevonyne
No it does not.
Old Jun 17, 2008 | 07:02 PM
  #58
Then I guess the description on thier website is exaggerating, and when I talked to them they told me wrong...
  #59
EvoDan2004's Avatar
There is a difference from saving static weight vs rotational weight. Just cause it says ''driveshaft'' does not mean its 15lbs rotational. Other things are removed/deleted.
Old Jun 17, 2008 | 07:03 PM
  #60
vwjeff's Avatar
this sounds like something I want
