QuarterMaster's Lightweight Driveshaft Replacement
Yeah, thats what I said, I do know the difference between rotational and static, the mounts of the driveshaft would be static, and like the website says its rotational, I called to confirm and thats what I was told as well.
Thank you vwjeff. Gladly someone understands me.
If the total savings is 14.5lbs then rotational savings I bet is less. I'm on my cell phone and its hard to explain but you I'm sure understand why.
Weight savings on something like a driveshaft are great even if the weight saved is very small.
The drive shaft spins roughly 4 times faster than your wheels, so if you take out 1 lbs of rotating weight from the drive shaft it would be like taking 1 pound off each wheel.
I was interested in the Devo shaft a few months back and I called to speak to them about it. They said that it removes one of the carriers and one of the joints in the shaft. The carrier is where you save most of the weight, and part of the carrier is rotational while part of it is not. They said that the driveshaft itself has to be made a bit thicker because it is longer without a joint and as a result the SHAFT only is a bit heavier.
Overall I took it that the back half of the shaft which gets replaced gains a tiny bit of weight, but the carrier goes away. I don't know how much the carrier weighs but I would guess about 14lbs or so. I am pretty sure almost all of the weight savings is from removing the carrier. I don't know what portion of the carrier is rotational so I can't say what is saved there.
13lbs of rotational mass is taken out by using this driveshaft... most of the weight is shaved off at the joints
1.5lbs is lost by the carrier bearing
thats your answer...
for what its worth, everyone who has had the driveshaft installed feels like their car has gotten significantly more responsive....
