How much boost can I run?
Old Jun 18, 2008 | 03:24 AM
Tracer's Avatar
Mods are in sig with the addition of an Ets 3.5" IC and ic piping. The power I made while getting tuned was on 23lbs. Is 24 or 25 lbs too much? I do want to still be totally safe as well!
Old Jun 18, 2008 | 03:57 PM
Tracer's Avatar
Anyone bump
Old Jun 18, 2008 | 04:00 PM
kanyonkid's Avatar
stay at 23... i stay at 21 becuase i wanna be super safe... but its ur ride so its ur call
Old Jun 18, 2008 | 04:09 PM
Boltz.'s Avatar
FCOTM Winner
You will be fine at 25. You might pull some timing but you won't damage anything. Your choice.
Old Jun 18, 2008 | 04:10 PM
IEXCELR8's Avatar
well what did your tuner say? If you are tuned for 23 stay there unless you get re-tuned for the higher boost.
Old Jun 18, 2008 | 04:12 PM
Dapper Dan's Avatar
depends on your tune.
Old Jun 18, 2008 | 04:18 PM
phabaznbro's Avatar
Run whatever you are tuned for...usually varying 1lb either way isn't going to matter...some tuners say up to 2...
Old Jun 18, 2008 | 10:00 PM
Tracer's Avatar
Tuner said he did'nt wanna runner higher than 23 I believe because of the IC . My Defi boost gauge is set @ 23 n 1/2 lbs. but I don't ever hit it, but don't defi gauges run a little high, i.e, it's set at 23 n 1/2 but actual boost might be 22lbs?
Old Jun 18, 2008 | 10:04 PM
evoracingstar's Avatar
pump gas stock turbo stock ecu 21-23 psi is fine with ur mods
Old Jun 18, 2008 | 11:49 PM
evopowned's Avatar
i would stay at 23 if your on 91 octane gas may opinion i mean you prob wouldnt hurt anything bumping it to twenty five but might get some knock here and there your call i think twenty three is perfect on 91
Old Jun 19, 2008 | 12:31 AM
Tracer's Avatar
Running 93 currently until I move back home to Norcal then 91. Had zero knock @ 23 lbs. but I am going to get retuned when I put the IC n piping on and hard intake pipe as well. Kinda leaning towards 24 lbs. Would like to get to 380awhp and 350lb ft. with the new mods and tune.
Old Jun 19, 2008 | 01:07 AM
EE's Avatar
EE
with 93 you can easily run 25 psi imo. I'm at 26, tapering to 22-23 at 7K!
gl
EvoDan2004
1959
Jun 4, 2025 12:32 PM
roidz3
Oct 1, 2015 03:53 PM
Blue91lx
Jun 29, 2013 06:46 AM
PatricksEvilEvo
E85 / Ethanol
11
Jan 3, 2012 10:23 AM
LEVIII
11
Apr 13, 2005 11:44 AM
