New FP White turbo
Old Jul 3, 2008 | 12:33 PM
  #301
GrocMax's Avatar
Here's some more stripchart goodness. Car is exactly the same as the white dyno setup, same boost control setup and all. Car is a 9 RS with weight ADDED and a full tank of gas.
You're seeing some new things here. The top time axis scale is an offset from just before the VSS picks up a signal. The cursor is at 59.9 MPH. Now I must admit the VSS (drive speed) calibration is off a slight amount, tires with a scootch different rollout are on the car.
Also included is the wastegate linear position (WG linear position) in raw volts.
Notice the same 'hit the wall' phenomenon exists in 4th gear, and its a little easier to see, but during 1st thru 3rd it runs clean till the tail end of 3rd.
The airflow was scaled to closely match the turbo RPM, you can see better how overspeeding the turbo causes the power to drop off at high RPM. This is
the compromise you get with a small turbine wheel, it spools and recovers quick, but you lose up top.
The boost pressure jumps up a little bit after shifts due to the extra load put on the engine during a WOT shift.
The driver could do a better job, he's a little slow on the shifts. Nothing a little practice won't cure.
Old Jul 3, 2008 | 12:57 PM
  #302
ForcedPerformance's Avatar
little slow on the shifts eh?! :P
BOOST ON!
Robert Young
Old Jul 3, 2008 | 12:58 PM
  #303
Indy Evo's Avatar
GrocMax, I heard the "pale" turbo running be prepared to sell a few very soon. Indy
Old Jul 3, 2008 | 01:00 PM
  #304
sk8terdude929's Avatar
What kind of turn around time is it for the evo IX turbo conversion?
Old Jul 3, 2008 | 01:03 PM
  #305
diiirk@AwdMotorsports's Avatar
Originally Posted by Mike01gsr
I just want a turbo that will do 400whp with supporting mods (exhaust, 02, ported manifold, cams, intercooler,) and have stock like spool at 22psi on 93. Is that to much to ask for?...lol
check my signature, the green is more than capable.
Old Jul 3, 2008 | 01:23 PM
  #306
Mike01gsr's Avatar
Stock like spool?
Old Jul 3, 2008 | 01:58 PM
  #307
TKEVO's Avatar
Veteran: Air Force
?...What r ya asking? Maybe I'm slow...haha
Old Jul 3, 2008 | 02:16 PM
  #308
Cali2MDevo8's Avatar
Registered User
He's asking FP how long it will take to convert his 9 turbo into a white turbo.
Old Jul 3, 2008 | 03:02 PM
  #309
It takes about a week to do the overhaul and update to the FPWhite Model.
I'm surprised there isnt more chatter about the data provided so far. Are the logs not very easy to read or understand?
BOOST ON!
Robert Young
Old Jul 3, 2008 | 03:10 PM
  #310
evoPirate's Avatar
Ill raise my hand on that one robert lol I don't understand a darn bit of that
Old Jul 3, 2008 | 03:21 PM
  #311
e55nEVO9's Avatar
I would suggest giving an easy to read conclusion for all those that dont wanna read all the advanced tech talk haha.
Old Jul 3, 2008 | 03:45 PM
  #312
03whitegsr's Avatar
BOOST ON!
Robert Young
OH OH
I KNOW!!!
As far as I've ever seen, your company is the only company to be so open with data. AWESOME
However, we have nothing to compare it against...I can see some interesting relationships between shaft speed, wastegate position, and exhaust backpressure. Charge temps pre and post IC would be interesting to see.
What were the details of the pass? Looks like a high 12 at 115-120mph on ~22psi?
  #313
evoPirate's Avatar
Easy to read conclusion = buy this turbo lmao
Old Jul 3, 2008 | 03:49 PM
  #314
hokiruu's Avatar
i too need cliff notes/layman's terms
Old Jul 3, 2008 | 05:10 PM
  #315
GrocMax's Avatar
It wasn't a pass at the drag strip. I think Robert's wife needed something at the store, NOW.
Originally Posted by 03whitegsr
OH OH
