10.72 @ 129 Red Turbo
Old Jul 11, 2008 | 09:37 PM
  #46
IHUNTV8's Avatar
Originally Posted by RyuEvoIX
Yes, any turbo will work with stock internals, just that thing that controls the boost is whats bad for them
Old Jul 11, 2008 | 09:39 PM
  #47
RyuEvoIX's Avatar
cute. Seriously though should the stock bottom end hold up to a race gas tune say around 35psi?
  #48
GarretEvo8's Avatar
What about running 22psi? 700cc injectors, Walbro and 98 Pump Gas.
Would that be ok?
Im only chasing 250 - 270 kw atw with the mods in my SIG. Will up the boost once i upgraded internals.
Im tossing up weather to go with this turbo or just stick with the green. Im looking for low 11's. Not wonting to go over 25psi..
Old Jul 11, 2008 | 09:42 PM
  #49
IHUNTV8's Avatar
Whats your connecting rods cell phone number i will call and ask? Hell i dont know, if your that worried about your motor blowing take up golf. Im just kidding with you im 6 beers in
  #50
sparky's Avatar
It should be good for at least a couple of runs at 35#, 8500 RPM.
Old Jul 11, 2008 | 09:44 PM
  #51
IHUNTV8's Avatar
Would that be ok?
Honestly i cant answer that question, but if you run 25 psi on this turbo i think it moves more air than a green at the same boost.
Old Jul 11, 2008 | 09:48 PM
  #52
GarretEvo8's Avatar
All these questions will be answered once this turbo is bolted onto an Evo with Bolt on mods.
Old Jul 11, 2008 | 09:51 PM
  #53
sparky's Avatar
What about running 22psi? 700cc injectors, Walbro and 98 Pump Gas...Im only chasing 250 - 270 kw atw with the mods in my SIG. Will up the boost once i upgraded internals.Im tossing up weather to go with this turbo or just stick with the green. Im looking for low 11's. Not wonting to go over 25psi..
98 R.O.N. pump gas is equivalent to our 93 octane R+M/2 gasoline in the States. You´ll be hard pressed to do low 11´s on pump gas with the Green and HKS 272´s. So, the Red is probably a better bet for you. The 720 nozzles are minimal even on a Green at 25 PSI/pump though.
Old Jul 11, 2008 | 09:52 PM
  #54
crcain's Avatar
IHUNTV8 can you post a datalog of a 3rd gear pull on the street so we can see when the Red hits peak boost? Or has spool info been posted?
I'm just wondering if this turbo slots in as being "better" than any current offerings out there. When speaking of response versus airflow.
Old Jul 11, 2008 | 09:53 PM
  #55
SloRice's Avatar
Congrats Trent!! Those 60ft's are crazy!!
Now go drink a few more celabratory beers!
Old Jul 11, 2008 | 10:00 PM
  #56
IHUNTV8's Avatar
I dont have a third gear log, I do have a 5th gear log and I floored the car at 3000 rpm and at 3400 i had 21.21 psi. I did different logs because i knew i was going to get a **** load of questions about it but no third gear pull by itself
Old Jul 11, 2008 | 10:01 PM
  #57
StreetThisEvo's Avatar
This is the most I've seen Trent online at one time haha.
Old Jul 11, 2008 | 10:02 PM
  #58
IHUNTV8's Avatar
Thanks Tim! My dog Turbo is drinking the rest of my beer, he cut me off
Old Jul 11, 2008 | 10:03 PM
  #59
GarretEvo8's Avatar
What size injectors would you recommend?
Old Jul 11, 2008 | 10:04 PM
  #60
I would say 780's for pump and/or race gas. And 1000-1200's for E-85..
