Separate Ignitor/Coil system working on stock ECU :)
Old Dec 29, 2008 | 09:30 PM
  #136
Broxma's Avatar
I'll be honest, I didn't get down to VatoZone to check. Lemme look online and see what I find.
/brox
Old Dec 30, 2008 | 06:21 AM
  #137
honki24's Avatar
When you guys get this all ironed out I'd love for someone to make a concise post that indicates all diagrams, all instructions, all claims of increased performance, and all part numbers found within this thread. lol, I'm an ME for a reason. Barely passed my EE classes.
Old Dec 30, 2008 | 09:39 AM
  #138
RunThat's Avatar
Could someone post up some info pertaining to this setup being used with the AEM EMS please, specifically, the AEM Coil Dwell Wizard choice I am going to have to make or the Coil Dwell settings themselves. Thank you!
Old Dec 31, 2008 | 08:43 AM
  #139
RunThat's Avatar
bump
Old Jan 1, 2009 | 11:14 AM
  #140
Evo8Emperor's Avatar
Im not sure if this has already been covered somewhere, but im wondering if there are better ignitors out there other than the dsm one ?
Im sure dsm guys have been on this for a while but I cant really say I worked on dsm's back in the day. Im just curious seeing if I spend the money I would always rather upgrade if possible.
Cant wait to try these coils out. I get blow out i believe usually part throttle in a high gear. I say I believe because I could be wrong but it hesitates when this happens and it like studders like when the car is cold.
Old Jan 3, 2009 | 08:11 AM
  #141
sabastian458's Avatar
will the ignitor from a 96-99 1.8 mirage work?
Old Jan 3, 2009 | 08:14 AM
  #142
its outward apperance looks the same as the ignitor from an 01 eclipse. but not identical to the one on the first page.
Old Jan 4, 2009 | 08:44 AM
  #143
RunThat's Avatar
What plug wires? No one wants to answer this
Old Jan 4, 2009 | 02:29 PM
  #144
RevMoto's Avatar
Has anyone found a connector that would allow this to be plug and play? I am not a fan of cutting my harness.
Old Jan 27, 2009 | 09:17 PM
  #145
evoixbri's Avatar
HKS DLI2 Wire Harness part #43999-AM001. It's $85 bucks. Anyone care to try it out ?
Old Jan 28, 2009 | 03:38 PM
  #146
crewdawg130's Avatar
on evo8's any DSM 8mm set.
Old Jan 28, 2009 | 06:56 PM
  #147
192raptor's Avatar
Veteran: Air Force
I just read through this thread and my head hurts!! Looks like a great idea for a budget ignition, especially for those that are funding for upgrades challenged.
Old Jan 28, 2009 | 07:01 PM
  #148
Yah I believe you want the dsm lead end for the head side as for the coil side I think dsm ones dont fit snuggly. Im just going to buy msd wires with the pencil style tops and go from there. I just got done making the bracket to hold it all.
Old Jan 29, 2009 | 05:50 PM
  #149
question to the ignition gurus....
Could you split the ignition input wire, say, for coil 1 to fire 2 ignitors?. For like wasted spark C.O.P??? is it possible.
Old Feb 13, 2009 | 10:41 AM
  #150
mrfred's Avatar
Originally Posted by Broxma
Here is the crude diagram I came up with and a few pictures of the install.
It is mounted on an aluminum plate I made at work through the two holes now vacant from removing the harness.
I put a bend in the mounting plate of about 15 degrees. It clears both the factory strut brace and the hood. I used some rubber between the plate and the valve cover to provide some flex. I didn't want the plate to break the valve cover with a rigid mount.
I took it out on the road and ran the car up to 7800 rpm, did a few 17 psi pulls in 2nd and 3rd and it performed well. The real test will be at the track in a few weeks.
Yes I built the short route UICP myself at work from some scrap mandrel bends we had lying around. I'm also building my own intercooler from core drops we have sitting around.
/brox
Props for Broxma for the clean install.
