Witch size block for hta37
Old Aug 24, 2008 | 12:33 PM
tripperfx3's Avatar
It really depends on what you want to do with the car. A 2.3 w/ HTA 37r is still a potent street car. I drove a friends AMS 2.3 w/ HTA 37r and it got full boost around 4300 or so and pulled til 7500 (thats where I stopped at least ) and it felt like it could have kept on going. If you want it to be a drag car go with a built 2.0 or even a 2.1 would be good for a little extra displacement and torque and rev the crap out of it.
Old Aug 24, 2008 | 12:54 PM
dsm25psi's Avatar
on a 2.0 should i see full boost around 5500 rpms?
Old Aug 24, 2008 | 01:05 PM
LT1runner's Avatar
Well I'm waiting on my twin scroll header. I've got a built 2.1 ltr, with BR\Indy's V2 intake and BR cams, and FPs 88HTA. I hope to drive it in two weeks. Hopefully I'll see full boost sooner than 5000. I maybe asking too much but we'll see.
Old Aug 24, 2008 | 01:41 PM
Ev0cRaZy's Avatar
Yeah around that area.
I say go 2.0 if you want a track car.
Old Aug 24, 2008 | 01:53 PM
Blizzackk's Avatar
with a 2.0 how high can you safely rev in a drag situation? I've heard of people revving all the way up to 11k but that's obviously on a fully built 4g63.
Old Aug 24, 2008 | 02:25 PM
Ev0cRaZy's Avatar
Seems like most people do 9k or so
Old Aug 24, 2008 | 02:44 PM
SpoolnupTuning's Avatar
with a built 2.0 and dualvavle springs, i rev to 10k pretty often.
Old Aug 24, 2008 | 05:07 PM
Ted B's Avatar
There is no reason to spin the motor higher than the optimum shift point, which is determined by the torque curve. For factory turbos through an FP Green, this is usually around 8000rpm. Spinning it harder is a senseless activity that makes the car go slower, significantly accelerates wear, and significantly increases the chance that something will fail - oftentimes catastrophically.
Old Aug 24, 2008 | 05:33 PM
dsm25psi's Avatar
where do u shift? since u got the p67 turbo what is ur spool like on it?
Old Aug 24, 2008 | 11:10 PM
Meanmachine04's Avatar
So...if i wanted the HTA 37R instead of the 35R i could keep the 2.0L? Would it be better to go to a 2.1L? Im not trying to set any records..im building a street/drag monster..if that makes any sense..ill do more street driving than track driving so im not sure what would be better....i also go to car shows but will go to the track whenever my friends go.... not trying to jack the thread but any advice for my situation?
Old Aug 25, 2008 | 04:15 AM
1NastyMR's Avatar
BUILT 2.0 for high revs
Old Aug 25, 2008 | 05:00 AM
Ted B's Avatar
Looking at my load curve, I estimate my optimum shift point to be around 9000rpm. That doesn't mean that I routinely use it - as I rarely need that much rpm to do what I'm trying to do. If I were trying for the best result at a drag strip however, that is what I would need to do.
My spool is fast for a turbo this size, but I have a twinscroll setup, so you can't go by my results . . . unless of course, you were going twinscroll.
Originally Posted by Meanmachine04
I'm not trying to set any records..im building a street/drag monster...
Then use the displacement/configuration that by far the most street/drag 'monsters' use. You already know the answer to your own question.
Old Aug 25, 2008 | 11:35 AM
Geoff Raicer's Avatar
a wise man once told me "R.P.M. = ruins people's motors"
ridenrunwv
E85 / Ethanol
15
Sep 16, 2015 05:11 PM
jfvhpilot
12
Oct 1, 2013 05:04 PM
Arandhawa23
13
Jan 3, 2013 07:28 AM
420a-t
Oct 17, 2011 04:44 PM
coffeeslug
May 9, 2008 11:01 AM
