An interesting dyno comparison of two EVO's
Old Sep 16, 2008 | 10:06 AM
m3jasper's Avatar
It's all about the area under the curve...
Thanks for the information and congrats on the low 9 second pass with the RS!
Old Sep 16, 2008 | 10:22 AM
Indy Evo's Avatar
"Same exact engines in both cars, same head ". DB
Except the RS has the Wilson v2 w/ a Buschur 65mm, Blackie has a HKS Kansai TB unknown .
Old Sep 16, 2008 | 10:24 AM
9sec9's Avatar
DB can't pull the seats out. Too many videos proving that it's a true daily driver to do that. When it goes 8's, I'm certain it's going to do it with dvd player and all.
Old Sep 16, 2008 | 10:27 AM
Indy Evo's Avatar
and the box in the trunk .
Old Sep 16, 2008 | 10:36 AM
9sec9's Avatar
WARNING:This DVD PLAYER will not operate at vehicle speeds in excess of 150 mph. Any attempt to operate and view a movie at this speed could make for a bad day at the track. Normal operations will continue when vehicle speed is lowered to normal levels.
Old Sep 16, 2008 | 10:46 AM
LoKiEvo's Avatar
Hey Dave whats the weight difference between the black car and your RS? You should consider throwing the turbo setup and intake manifold from your RS on the the black drag car... it seems to me to be a more efficient and powerful setup.
Old Sep 16, 2008 | 10:57 AM
Erik@MIL.SPEC's Avatar
Who makes this new FS turbo?
Old Sep 16, 2008 | 12:18 PM
vwjeff's Avatar
WOW what a difference
I am speechless...
Old Sep 16, 2008 | 12:54 PM
scheides's Avatar
EvoM Moderator
Now how about a comparison between your old HTA35 and this new FS635?
Lookin mean!
Old Sep 16, 2008 | 01:12 PM
AFI Turbo's Avatar
Originally Posted by Mellon
so much for twin scroll being magical but I'm sure the turbo/cam difference plays a role as well.
You can't make an assumption like that...First of all the .84ar housing is too small. Needs a 1.06 or bigger atleast. There has to be something else going on. Our Honda, yes i know its not a 4g63 but its a 2.0L with a smaller stroke than 4g63's has peak tq @ 6800rpm's with a gt4202r. The only reason im making a comparison is we had a gt35r on the car awhile back (open housing t3 .82ar) and it didn't spool as fast as David's rs or have anywheres near that midrange, so the spool isn't coming from the difference in engines.
For reference here is a t4/t61 (same p trim exhaust wheel, 61.5mm comp) with a .96ar t4 twin scroll hsg on a stock 4b11t. Cams would wake it up another couple hundred rpms atleast, Im also sure more tuning could get another couple hundred rpm's of spool. Peak tq is about ~5000rpms. There is no reason a turbo with a slightly bigger compressor wheel ( and the HTA was supposed to spool faster than the cast wheel correct?) is spooling that much later, especially on a motor with good headwork, cams, etc like that.
Either way the RS is truly a badass car, i can't think of anything else that impressive in awhile
Old Sep 16, 2008 | 01:21 PM
9sec9's Avatar
Too busy to do the comparisons: Here's the long and short of it.
You start here.
When you're through here, you go to step 1.
Then make sure this is working properly.
If you go into OVERLOAD, this is what happens:
Then, you start over:
Old Sep 16, 2008 | 01:22 PM
MRfabolous's Avatar
i had a feeling when i bought the hta35r it would be obsolete one day.
Old Sep 16, 2008 | 01:24 PM
AWD Motorsports's Avatar
Like anything, someone will always come out with something superior eventually..
Old Sep 16, 2008 | 01:28 PM
Mellon Racing's Avatar
you're telling me not to make assumptions and you're coming in here with a honda dyno chart GTFO
SPIN2GST's Avatar
Nice comparison David. I bet it really makes you think about the set up on the black car now.
