Green Dyno Sheet Review
Old Sep 23, 2008 | 03:52 PM
FastAzzEvo's Avatar
low? or about right? I know I need intercooler,, it was heat soaking bad...
23psi on pump
mods green, cosworth m2, 780cc, mr turboback, apexi filter, greddy profec type s, ams licp, mr o2 housing, 255lph walbro... all else stock
temps were around 106degree
Old Sep 23, 2008 | 03:54 PM
1320 Engineering's Avatar
looks about right for the mods
intercooler and ported exhaust manifold.
oh and turn up the boost!
Old Sep 23, 2008 | 04:12 PM
Craig King's Avatar
Looks OK, but like he said ^^^ turn the boost up a little more and you'll see closer to 375whp.
Old Sep 23, 2008 | 04:54 PM
Jeff_Jeske's Avatar
The green thrives at higher boost levels. You need to toss some high octane fuel or injection of some type at that beast. With meth or race gas you should be knocking on the 400whp door.
Old Sep 26, 2008 | 09:30 PM
FastAzzEvo's Avatar
i wanna extract the most power as i can with just boltons... on pump 93 at the same boost level... before raising boost and going race/meth..
anyone with green all bolt ons on pump 93 at same boost level 22-23 making 400whp with no knock?
is it even possible?
I don't even think an intercooler would do **** without raising the boost. like i don't believe an intercooler would make power just bolting it up.. and touching nothing... i could be wrong though
Old Sep 26, 2008 | 11:54 PM
Jeff_Jeske's Avatar
^ not gonna happen. You need to run higher boost. Two gallons of race gas will completely change your cars performance. Don't even dick with pump.
Old Sep 27, 2008 | 07:44 AM
Mellon Racing's Avatar
looks very low to me but you don't have the best supporting mods either..
stock mr turboback and stock fmic have to go.
also it wasn't 106* in Georgia ...where did that temp reading come from?
Old Sep 27, 2008 | 08:25 AM
boostedwrx's Avatar
Dang I missed that stock mr turbo-back. Owch!
Old Sep 27, 2008 | 08:29 AM
MR Turco's Avatar
Oh i thought he meant he had a Megan Racing turboback. If he has a GSR i am not sure why he would swap for a stock MR tbe.
Old Sep 27, 2008 | 08:33 AM
bluebanana23's Avatar
+9526487
Old Sep 27, 2008 | 08:34 AM
ExViTermini's Avatar
definitely means megan...
Old Sep 27, 2008 | 08:35 AM
cssaddictm4's Avatar
+1 Because he also states that he has a MR 02 housing. I don't think someone would waste money on OEM parts like those. Maybe he is getting an air temp reading after the intercooler?
Old Sep 27, 2008 | 08:38 AM
boostedwrx's Avatar
Ah ok Megan Racing. Anyway, looks like the tune could use some work along w/more boost.
Old Sep 27, 2008 | 09:46 AM
FastAzzEvo's Avatar
yes megan racing turbo back including megan o2 housing, but now I have the epm dump o2..
it was over 100deg this dyno was done back in august.
also the car was tuned without cams...
so the tuning was of the cams, and fine tuning, and a lil more boost.
I know I need an intercooler, but I don't think that will do anything except help with heat soak.
i don't think i'll even gain 10whp from an intercooler..
however, I do agree race/meth will do wonders.. I'm just trying to get what I can get before stepping up to race or meth
FastAzzEvo
123
Dec 26, 2007 02:46 PM
FastAzzEvo
25
Nov 6, 2007 09:00 PM
FastAzzEvo
12
Nov 4, 2007 11:11 AM
FastAzzEvo
51
May 21, 2007 06:44 PM
FastAzzEvo
Jul 21, 2006 03:09 PM
