Loud Engine BANGING
Old Sep 25, 2008 | 06:25 PM
Jaywheels3's Avatar
Loud Engine BANGING
As I was on my local commute home, I had an a**hole decide to pull in front of me without signaling while I was changing lanes. In my panic, I slammed on my brakes and left my foot off of the clutch. I started to hear/ feel a loud banging coming from the front end of the car. It wasn't the traditional ABS kicking in. It was coming from what I thought to be the engine or transfer case. Any one had some similar situations? Any help would be great.
Old Sep 25, 2008 | 06:34 PM
Duh Panda's Avatar
thats no goood... the car was still in gear and you braked hard? from what speed to what? ehhhhh i wouldnt even know what would be involved in that.. maybe trannny?
Old Sep 25, 2008 | 07:07 PM
ONRAILS's Avatar
did you try to repeate the sound?
Old Sep 25, 2008 | 07:14 PM
S2myEvo's Avatar
what gear were you in? also what was ur speed when you slowed down?
Old Sep 25, 2008 | 07:20 PM
Duh Panda's Avatar
you have the gayest avatar....
that is all...
BUMP for the OP to list details
Old Sep 25, 2008 | 07:46 PM
Jaywheels3's Avatar
I was in fifth from about 50 to 5. I would never dream of repeating the sound. It was horrible.
Old Sep 25, 2008 | 07:47 PM
Duh Panda's Avatar
that woould do it!... does it still make the sound?
Jaywheels3's Avatar
No it doesn't make the sound, but what was the banging sound I heard?
Old Sep 25, 2008 | 07:50 PM
Duh Panda's Avatar
my .02cents would be your whole motor/tranny..
your talking about going from 50mph to 5mph in 5th gear with the clutch still engaged....
if it isnt making the noise anymore..
jusss shh.. it never happened.. maybe it was a dream?
Old Sep 25, 2008 | 07:53 PM
typac69's Avatar
yea thats sketchy and new to me... i would just keep your ears listening and try not to redo it to see if it does it again.. Keep us updated on how everything sounds....
Old Sep 25, 2008 | 07:56 PM
sharkm87's Avatar
maybe motor moved....downpipe hit suspension...idk...
Old Sep 25, 2008 | 08:18 PM
sho669's Avatar
More than likely it was just clutch chatter from the engine trying to pull the car while still being in high gear at low speed. Drivetrain lash makes it sound a whole lot worse that it really is. I did the same thing in one of my other cars, pretty much any manual trans car will do it. I don't think you should have to worry about long term damage though.
Old Sep 25, 2008 | 08:32 PM
SRT-TO-EVO's Avatar
I know EXACTLY the sound you're talking about. It's only when you slam on the brakes and the front dives, and you a hit a slight road imperfection. It's happened to me a couple times but only when brakes were slammed on, and it sounds like a huge thump from the front/bottom of the car. I noticed my car does it alot more often and it slowly got worse since I put the parts on, for almost every time I brake/release clutch or roll back on a hill it's a slight thump from the front/bottom. I'm taking it to Mitsu soon so I'll let you know what it is. I'm 99.5% positive it's suspension related (maybe front swaybar?) because it will happen to me in neutral rolling on a hill pressing the brakes, or rolling and my front left/right are on uneven surfaces with no brakes applied.
Old Sep 25, 2008 | 08:52 PM
huevosrancheros's Avatar
it was probably your moustache bar in the rear end making that sound.
Evodetailer123
May 31, 2015 07:57 AM
dangle
15
Feb 5, 2012 10:18 PM
WangMan
Lancer Troubleshooting
Sep 30, 2011 05:42 AM
evo585
May 13, 2009 07:12 PM
GottaGoFaster
18
Apr 7, 2004 10:19 AM
