Aftermarket FMIC install tips?
Old Oct 25, 2008 | 07:27 AM
Vibrant's Avatar
Bought a new intercooler and it didn't come with mounting brackets, just tapped holes where the brackets should mount to. Do I just drill out the tack welds on my stock IC and then drill holes in the bracket to mount it? The top bracket doesn't seem like it will give me any problems, the two side mounts look to be a little more dificult. Any suggestions? How did you guys do it?
Old Oct 25, 2008 | 07:29 AM
BaLListic_EVO's Avatar
i got a cheap *** ic too but it came with brackets? not real sure
Old Oct 25, 2008 | 07:33 AM
Vibrant's Avatar
Yeah, I picked it up from another evo owner. I think he said the brand was godspeed, or something like that. Either way, was wondering if the top bracket and the inlet/outlet would be enough to support it.
Old Oct 25, 2008 | 07:36 AM
Craig King's Avatar
I had a Godspeed intercooler on my last car. It didn't come with brackets either - between the intercooler pipes connected to it and a tight fitting bumper, I just used bailing wire to "hang" it from the crash bar.
Old Oct 25, 2008 | 07:41 AM
Jason05RS's Avatar
The fact that you own a 35,000 car and did that is crazy.....i would completely expect that on a riced out 93 civic but not an evo
Old Oct 25, 2008 | 07:47 AM
Vibrant's Avatar
Agreed. I am trying to do this the correct way. I want longevity and a clean install.
Old Oct 25, 2008 | 08:07 AM
Jason05RS's Avatar
If you dont have a tig welder and access to aluminum flat bar, then here is my suggestion....
Use the piping to hold the intercooler in place. Go to a local hardware store and by some steel flat bar. As long as you have a vice, hammer, and a drill you can bend some brackets and not only bolt them into the threaded points on the intercooler but also to the stock locations on the car. Get some spray paint too so the metal dosent get rusty....Maybe $10 bucks for the material and $5 for the spray paint.
Old Oct 25, 2008 | 10:36 AM
letMeIn's Avatar
since you trying to save $$ by buying cheap IC that have no brackets, may I suggest tiewraps or duct tape to hold it in place ?
Old Oct 25, 2008 | 10:40 AM
BorisTheBlade's Avatar
ditch the cheap intercooler and get a quality one
Old Oct 25, 2008 | 11:22 AM
justboosted02's Avatar
make some out of aluminum strips, you can get them at home depot
InitialE
Mar 17, 2016 01:21 PM
wicked white x
Oct 17, 2012 12:16 PM
OverCorrupt
Feb 16, 2012 09:12 PM
EVO8emUp
Oct 5, 2011 04:46 AM
Kayaalp
Mar 2, 2004 08:22 PM
