Possible boost creep
Old Oct 30, 2008 | 10:37 AM
thadon84's Avatar
27 psi boost spike stock MR.
I noticed the other day on the highway when I floored it in 4th that my mitsu gauge showed a spike past 1.5 to around 1.8-2.0 bar before leveling off between 1-1.5 bar. I did the psi conversion and 1.5 = 21.7 PSI and 1.8 = almost 27 psi. I would imagine that 27 psi on 91 oct untuned is a problem.
Anyways I did some more testing last night and in 1st and 2nd gear I spike to 20psi and then level out at 17-18 psi, but in 3rd and 4th I spike to 26-28psi and level out on 17-18psi.
I bought the car last week and it is a stock IX MR. I checked but did not see any kind of boost controller so I believe it to be stock. I plan on doing some more checking this weekend but wanted some direction.
Any help or thoughts would be appreciated.
Thank you
Old Oct 30, 2008 | 10:47 AM
TeStUdO's Avatar
Higher gears=More load
More load=More boost
Check for a boost controller and turn it down. That is WAY too high.
Old Oct 30, 2008 | 10:50 AM
thadon84's Avatar
Thank you, I will stay out of boost until I sort this out.
Old Oct 30, 2008 | 11:00 AM
MaxKanisha's Avatar
What you are experiencing are boost spikes, not creeps. Boost creep is when your boost continues to rise towards redline, meaning your wastegate cannot bypass the amount of exhaust it is suppose to.
Someone please correct me if I'm wrong.
Old Oct 30, 2008 | 11:04 AM
thadon84's Avatar
ok you are right I google it and found this on dsm tuners.
http://www.dsmtuners.com/forums/arti...ost-creep.html
So I may either have an mbc which is set to high or a faulty stock boost controller?
Old Oct 30, 2008 | 11:17 AM
MaxKanisha's Avatar
Correct. If you don't have an MBC, its possible that someone removed the restrictor pill in your boost lines. I'm not too sure exactly on how that works, but I heard removing it can raise your boost to 25 PSI.
Old Oct 30, 2008 | 11:22 AM
thadon84's Avatar
ok I will search for info on this and take off the stock airbox to get a better look at the situation, thanks for the help.
Old Oct 30, 2008 | 01:04 PM
thadon84's Avatar
ok I checked and no MBC installed, the stock lines seem to beem connected correctly. Any chance that there is a tune on my ecu?
I am wondering if I should just take it to Mitsu and see what they say.
Old Nov 1, 2008 | 07:19 PM
sparky's Avatar
If you go to the parts counter at the dealership and get a new vacuum/boost hose assembly, and remove what you have and install the new factory one then let us know if it still spikes. Probably the previous owner either removed the restrictor pills in the factory hoses and/or was running a boost controller and reinstalled other non factory hoses before he sold you the car.
AlDim
21
Jan 11, 2014 05:34 PM
IAmADirtDude
21
Jun 12, 2008 04:21 AM
urnamehere
11
Jan 10, 2008 03:58 PM
SPOOLD
Dec 6, 2007 01:31 PM
turboex
Dec 1, 2004 06:17 PM
