Clutch Replacement
Old Sep 4, 2003 | 03:42 PM
PocketAces's Avatar
Clutch Replacement
My car is at the dealer up on the rack right now with the tranny and everything out for what "should be" warranty work. The service manager told me that he would put an aftermarket clutch in for free while he had everything taken down.
Now I hear awesome things about the Exedey but it's price is near $1000. I would only get the single disc since that appears to be more than enough for my application. I am also looking at the Clutch Master Stage 1 which is about half the price. I wouldn't consider CM Stage 2 or 3 because if I was going to buy that one, I would rather just spend the extra and buy the Exedey.
I do mostly road course racing but would like to do the occaisonal high RPM clutch drop at the drag strip. I dont anticipate having more than 330-350 WHP in the next 2 years or so.
Any clutch experts have a suggestion?
Old Sep 4, 2003 | 03:57 PM
Thoe99's Avatar
Can't answer your question, but what's wrong with your car to begin with?
Old Sep 4, 2003 | 04:01 PM
Keyser Soze's Avatar
He is having some tranny problems with his car.. Referenced here https://www.evolutionm.net/forums/sh...threadid=37778
Old Sep 5, 2003 | 07:05 AM
PocketAces's Avatar
5th gear syncrho is out.
Old Sep 5, 2003 | 09:05 AM
evo1's Avatar
Re: Clutch Replacement
Yo Bidness!
Road Race Engineering just go its first shipment of ACT clutch kits, and it's a single disk design (basically a Mitsu that has been redesigned), the pressure plate is around 3100lb. (40% more clamping power over stock). Much more streetable too, opposed to the Exedy kits, and the price is right! Only $490 for ACT kit ... comes with everything except for allignment tool. I ordered mine a couple dayz ago. If you want one, I would call quickly because once Evo-m members find out they are ready, they are going to fly off the shelf -- Dirk Starkson @ ACT has been posting here for a while now.
Old Sep 5, 2003 | 09:20 AM
erikgj's Avatar
Re: Re: Clutch Replacement
evo1-
Let us know how you like the clutch. Are also doing a lightweight flywheel?
erik
Old Sep 5, 2003 | 09:24 AM
PocketAces's Avatar
evo1--that sounds like a good deal on those clutches, but they will eventually need to be replaced. I would rather just spend the money now and not have to worry about ever replacing my clutch again. However, if for some reason it doesn't financially work out where I can get the Exedey, then I will take a look at those.
What is the "Road Race Engineering" website?
Old Sep 5, 2003 | 09:42 AM
evo1's Avatar
Re: Re: Re: Clutch Replacement
Originally posted by erikgj
evo1-
erik
Well i was going to, but now I'm hearing bad things about them for street use ... so I'm not so sure now.
Old Sep 5, 2003 | 09:46 AM
evo1's Avatar
I hear ya ... but are you sure you want a clutch that strong? You could end up breaking other things (tranny etc) if you are not careful.
http://www.roadraceengineering.com/SiteMap.htm
Old Sep 8, 2003 | 06:14 AM
sir lurks alot's Avatar
People will definitely start breaking stuff with a stage 3, like differentials and tranfer cases. I would rather replace a clutch every 50k than a $2000 transfer case.
Kasey
11
Jul 24, 2014 11:29 AM
EVO X 6950
Jan 19, 2012 04:01 AM
Vivid Racing
Sep 13, 2010 11:49 AM
03eh_VE_oh_VIII
10
Sep 28, 2009 08:22 AM
RevMoto
26
Feb 19, 2008 08:29 AM
