FP RED setups, recommendations, and advice
Old Nov 14, 2008 | 01:09 PM
FastAzzEvo's Avatar
what about Diverter valves? Is the oem ix good enough for 30psi on red?
I know I can't do a vta, but was wondering what everyone else with red's are using for DV/BOV ?
Old Nov 14, 2008 | 01:22 PM
mr-derer2's Avatar
Here's my setup below.... Im going to be porting my turbo. also my intake and exhaust mani soon and adding a aem ems to try to squeeze every drop out or her. Im hoping for 550whp.
Old Nov 14, 2008 | 01:57 PM
GrocMax's Avatar
Injector sizing is relative to fuel properties/differential pressure, max engine RPM (available inj time per cycle), and ECU/induction strategy. While one car may be overkill on 850's another will be needing 1200's.
Old Nov 14, 2008 | 02:03 PM
TxEvo8's Avatar
Some say that if you crush it, then it will hold 30 psi, but it will only hold 25-27 without crushing. I went with the Forge RS, much better!!!
Old Nov 14, 2008 | 03:42 PM
Evo H8's Avatar
I've been using Forge diverter valves on my turbo cars for years and years... they have always worked flawlessly.
Old Nov 14, 2008 | 08:14 PM
Shacochis06's Avatar
i did 379/313 on a mustang dyno that reads dead on with Buschurs dyno with a stock IC/block/ecu 93 oct at 26psi...
turned up the boost to 30psi 421/355.....93oct....so you can see with 4psi more i picked up almost on 40hp and torque went up...
If anybody planning on running boost levels lower than 25psi id stick with the green...the red does love boost but can still perform awsome in 25-30psi levels..
Old Nov 14, 2008 | 08:18 PM
SRT-TO-EVO's Avatar
Going with the APS Twin.
Old Nov 14, 2008 | 08:28 PM
phizzalot's Avatar
SRT-TO-EVO How much do you expect to make with what you have in your sig and pump 93 vs E85?
Iam thinking of an fp Red as well but I have to get a shopping list together to prepare for it. My mods in my sig is just a start and Iam sure I have a lot more to add....
Old Nov 14, 2008 | 11:04 PM
Dr. SS's Avatar
i am still on stock clutch, syncro's, etc. 44,000 miles. mods below. (someone asked earlier if anyone was on stock clutch)
i had a plastic stock BOV, AMS recommended a billet samco sport DV. car is tuned for E85 holds boost fine with no bucking or drivability issues. AMS ftw.
Old Nov 15, 2008 | 09:16 AM
ernald711's Avatar
looks like i'll be running 880's or 1000's. i plan on adding the cams in the spring.
Old Nov 16, 2008 | 12:22 PM
SRT-TO-EVO's Avatar
Well on E85 I know I should be REAL close if not at 500whp. But the RED isn't going in until cams get here, ported intake mani, TB, injectors etc. I'm still contemplating on the stock ECU or AEM EMS.
Old Nov 16, 2008 | 10:20 PM
stikiller214's Avatar
PROFORMANCES MODS
aem tru boots(with upgrade)
walbro 255
Megan 02 housing
HKS 272 intake/EX
ARP head studs
hks 3in carbon ti ex
DC 3in downpipe
aquamist meth kit
Ported manifold from buschur
buschur racing fmic
HKS Dli-II
precision 880cc
DYNOFLASH tune 2morrow(he told me 500whp)
Old Nov 18, 2008 | 10:36 AM
ernald711's Avatar
Originally Posted by stikiller214
PROFORMANCES MODS
walbro 255
Megan 02 housing
HKS 272 intake/EX
ARP head studs
DC 3in downpipe
aquamist meth kit
buschur racing fmic
HKS Dli-II
precision 880cc
meth does wonders.
Old Nov 18, 2008 | 11:29 AM
Smoothgangsta's Avatar
Does anyone have a side-by-side picture of the IX turbo and RED? Or IX -> Green -> RED...that would be neat to see all 3 size wise.
Old Nov 18, 2008 | 12:57 PM
Evolessfornow's Avatar
Anyone using bigger oil feed lines for the Red? Or is everyone using the OEM oil feed hard lines?
