Ted B.'s HTA3582 Twinscroll Project
Old Mar 2, 2009 | 02:19 PM
  #121
EvoDan2004's Avatar
Originally Posted by 11secDSM
Ted- not sure if I missed it in this thread...who makes the 1.06 div t4 housing for the 35r? Was it machined to fit? Thanks for any input.
EDIT- is it the ATP housing?
yes its a ATP t4 housing. you do not need it machined to fit. they make it for the 35r turbine wheel
  #122
Ted B's Avatar
Both turbine housing and flange are ATP items. On an added note, I prefer to match housing and flange to a single manufacturer, as the ATP flange and Garrett flange appear to be ever so slightly different.
Old Mar 15, 2009 | 04:50 PM
  #123
Max Power's Avatar
Ted - I'll be interested to hear how your car does fuel wise with the 1450's. I'm finishing up my 1.06 TS T3 35R right now and plan on running the 1450's on e85. I hope that pump system keeps up.
Old Mar 15, 2009 | 05:50 PM
  #124
Ted B's Avatar
I've decided to stay with the 1250s and up the base FP to 50-55psi. That should not present anything that isn't within the capacity of the pumps according to the test data I have. The point that needs to be emphasized is if one disables the FP release valve, he damn better be sure to check//clean/change the fuel filter on a regular basis.
Meanwhile, I'm still paralyzed by a leaking Hypertune TB, patiently awaiting a replacement . . .
Old Mar 15, 2009 | 07:46 PM
  #125
Driven Innovations's Avatar
Im working on that Ted! They are killing me...
Old Mar 15, 2009 | 07:59 PM
  #126
Ted B's Avatar
It's not your fault Tom, so no worries. We're both victims of their carelessness.
Old Apr 14, 2009 | 06:53 PM
  #127
SilverBulletIX's Avatar
Any updates Ted B?
Old Apr 14, 2009 | 07:00 PM
  #128
Ted B's Avatar
Still awaiting a replacement TB from those slowpokes at Hypertune in Australia.
Old Apr 14, 2009 | 07:07 PM
  #129
You know it's serious when you're waiting for parts from half way around the world
Old May 16, 2009 | 11:18 AM
  #130
E85evo8's Avatar
was curious to know what kind of problems you were having with your FPR? I'm running an Aeromotive FPR@50psi base/idle....
Old May 16, 2009 | 12:56 PM
  #131
Evolved_6's Avatar
He made a separate post about it do a search under his user name.
Old May 16, 2009 | 01:03 PM
  #132
Evolved_6's Avatar
here you go
https://www.evolutionm.net/forums/ev...regulator.html
Old May 16, 2009 | 01:26 PM
  #133
E85evo8's Avatar
ok, thanks! I have a different version Aeromotive regulator than Ted B and mine holds FP under boost as well as slowly bleeds off when I shut off the ignition
Old Sep 6, 2009 | 09:51 AM
  #134
William254's Avatar
any results on this setup yet?
Old Sep 6, 2009 | 10:31 AM
  #135
Ted B's Avatar
Well, the replacement throttle body apparently has a return spring with too much tension, so once again, I am awaiting a replacement!
