Air Filter Shootout Test - Results!
Lets say we have two intakes that flow exactly the same amount of air at a given pressure, one causes the air to lfow in such a way as to produce more eddies, the ECU will see this as a greater air mass, and give more injector pulse width and make the mixture rich. The other air filter flows the same amount of air, but causes a smother flow, so the ECU see this as less air flow, and gives less injector so weaker mixture.
So nothing to do with flow, everything to do with eddies ( vortices ).
. I am using AMS intake pipe.
