Tomei Arms Turbo installed!!!
Old Feb 6, 2009 | 12:09 PM
  #91
CWiLL's Avatar
Originally Posted by Arkitek
turbo sounds promising! was these all done of stock block?
yes stock motor with cams and headstuds
Old Feb 6, 2009 | 12:56 PM
  #92
Steve93Talon's Avatar
Originally Posted by roger smith
Also looks like you can buy the parts of this turbo separately + overhaul kit.
Where did you see/hear this? If it's true, I wonder if the compressor housing will bolt onto an OEM IX turbo. If that's the case, someone needs to buy a comp. housing and send it in to FP with their IX turbo for a Red conversion.
Old Feb 6, 2009 | 01:07 PM
  #93
AWD Motorsports's Avatar
Originally Posted by scheides
Post the graph already!
And how much are these things?
The pricing is 1695.00 shipped right now.. They come complete with brand new stainless lines, actuator, and Gaskets.. I have 10 i am going to reserve for the next shipment.. Those of you interested i would get in a deposit to get your name assigned to one when they show up.. Thanks!!
Mike
Old Feb 6, 2009 | 01:12 PM
  #94
dustin03's Avatar
nice numbers whas that on pump or e-85
  #95
EvolNinja's Avatar
Damn, that turbo looks b e a u t i f u l
Old Feb 6, 2009 | 01:13 PM
  #96
03whitegsr's Avatar
Sounds promising. It will be interesting to see the run conditions though as it sounds like the Tomie had a distinct advantage with regards to temperature. For comparison sake though,
FP Green ($1695) + FP EVO8 Install Kit ($129) = $1824
FP Green ($1695) + FP EVO8 Install Kit ($129) + FP High Pressure Actuator ($129) = $1953
If that Tomie Actuator is a high pressure actuator, and the price is around $1700 (stated price in other threads) this turbo is quite the deal compared to the Green when upgrading from an VIII.
Old Feb 6, 2009 | 01:14 PM
  #97
andrewzaragoza's Avatar
do you know what is the spring rate on the actuator? if its close to stock then an upgraded actuator would help.
Old Feb 6, 2009 | 01:17 PM
  #98
Guerillah's Avatar
WOW, big gains. I dont think 9 degrees and 16% humidity is going to account for 40whp/50tq. Bad *** turbo.
Old Feb 6, 2009 | 01:18 PM
  #99
E-85 fuel..
Old Feb 6, 2009 | 01:23 PM
  #100
Guerillah's Avatar
Can someone confirm if the turbine housing was ported or needs ported? Was the green that was on before ported or not?
Old Feb 6, 2009 | 01:25 PM
  #101
03whitegsr's Avatar
Based on the dynosheet run parameters, these would be the corrected peak numbers of both runs.
Code:
		                        Uncorrected           Corrected
	Dyno Correction Factor	    HP	   Torque	       HP	Torque
Tomie	    0.948	           481	   475                 456	  450
Green	    0.992	           441	   426	               438	  423
Old Feb 6, 2009 | 01:37 PM
  #102
sspaladin28's Avatar
Nice work guys, glad to see that overlay and to see this thing spool like a champ, while still carrying a huge mid range advantage
Old Feb 6, 2009 | 01:41 PM
  #103
Tonba's Avatar
Makes me want one.. but now im hit with the question..
To go a Tomei or a BBK??
Old Feb 6, 2009 | 01:44 PM
  #104
^Question of the day right there
Old Feb 6, 2009 | 01:52 PM
  #105
Guerillah's Avatar
Test a BBK Full on this bad boy next
