4G64 Long Rod 2.2L Build
Your probably right. But I felt dumb when I realized the problem because in hindsight, I couldn't think of any good reason why a loose bolt or nut holding the oil pump sprocket would stop a leak.
I was scheduled to get tuned tonight at 9:00PM, but I'm still having trouble with the turbo fittings. The 1.00 T4 exhaust housing on a GT35r size turbo makes for one tight package. I should get my order from FP tomorrow and hopefully everything will fit this time around.
I finally got the right fittings to put the turbo together, and the turbo is in the car. Damn TS makes for a tight fit. One of the wastegate dump tubes was touching the radiator, and I didn't feel comfortable with it there, so I am now trying to figure out where I am going to re-route it. There's nothing like having to modify almost every part of a kit that you bought to save time
. Anyways, I wanted to get your guys opinion on routing one of the dump tubes out of the hood vent. It sounds kinda ghetto, but I have seen it done before, and it actually didn't seem like that bad of an idea. Aside from some occasional flame throwing and a little soot, I don't see any drawbacks. I'm also going to have to figure something out for the upper radiator hose, but that can wait a couple days. Btw, the bigger turbo, o2 housing, and manifold sure made the car a lot louder.
Looks terrific. Sorry about the fitment issues. I think you were right about the radiator.. my friends a/c condensor ended up touching his radiator and after a while killed the radiator.
Good luck sorting things out.
I re-routed the driver side dump tube, so I think everything is good now. I decided against routing the dump tube out the hood vent because I don't really want to have to worry about the car sitting out in the rain and having the wastegate full of water.
I also noticed after I turn the car off I can hear the turbine spinning down for 5-10 seconds. Is that just because it's ball bearing? I've never noticed that on any other turbo.
Yep sure is. Mine spins for almost a minute after I turn the car off! Depends on your intake pipe as to how loud it is
