The Best Stock Turbo Manifold?
Old Sep 24, 2010 | 09:19 AM
  #361
griffeyr's Avatar
I just ordered the CBRD/JM Fab for my 9...i'll let u guys no how it goes with the retune
Old Oct 3, 2010 | 02:15 AM
  #362
eTiLiKo's Avatar
Originally Posted by FiD-Turbo.com
The runners are 1.42" ID (1.25" schedule 10) for our FiD stock tubular manifold.
Sorry but my english isn't so good...what do you mean with "1.25 schedule 10"? The diameter is 1,42" or 1,25"??
Old Oct 3, 2010 | 06:30 AM
  #363
mrfred's Avatar
He means 1.42" outside diameter and 1.25" inside diameter.
Old Oct 3, 2010 | 11:52 AM
  #364
06MREvo's Avatar
I heard you will be testing out some manifolds soon sir...very nice...
Old Oct 3, 2010 | 12:16 PM
  #365
bbyevo8u's Avatar
do you know the diameter of the full-race stock frame mani?
the diameter on the full-race looks a little small or is it me?
Old Oct 3, 2010 | 01:49 PM
  #366
mrfred's Avatar
Don't know, but I'd guess that it the same - schedule 10 1.25".
Old Oct 3, 2010 | 08:41 PM
  #367
FiD-Turbo.com's Avatar
The 1.25" schedule 10 piping (weld els) measures 1.42" in I.D. (Inner Diameter). The 1.25" in size is refer to as nominal pipe size. A thicker schedule 40 in 1.25" piping would have a thicker wall than a schedule 10, however the I.D. of a schedule 40 of the same size piping would be smaller.
Pipes and tubings are measured differently. A 1.25" tubing measures 1.25" O.D. (Outer Diameter). However, a 1.25" piping measures 1.66" O.D.
MrC
Old Oct 4, 2010 | 05:02 AM
  #368
blkVII's Avatar
So whats the best ported stock manifold to go with? The tubular manifolds r a bit on the exxy side.. Are they really worthwhile over a ported stocker??
Old Oct 5, 2010 | 02:12 PM
  #369
TalonFiero's Avatar
I had some doubts, then I had the opportunity to try out the FiD Tubular manifold at my buddies Race Shop, DB Performance.
did three baseline pulls with the MAP ported stocker, swapped to the FiD manifold right on the dyno and 30 minutes later did three more pulls without touching boost or the tune. Picked up 20hp over the ported stocker but more importantly picked up power everywhere with really minimal increase in spool.
Here is a link to my testing.
https://www.evolutionm.net/forums/ev...-manifold.html
Old Oct 5, 2010 | 03:01 PM
  #370
RockmanX's Avatar
wow this never ending fight
Old Oct 5, 2010 | 03:11 PM
  #371
03whitegsr's Avatar
Originally Posted by 03whitegsr
I'm running a 1-1/2" (pipe) tubular manifold with ~17" runner lengths. Most of the others out there seem to be 11"-14" runners and most are using 1-1/4" pipe. My car holds HP pretty well out to 7500 even on the stock IX turbo. It is more "laggy" then a ported stocker, although, I wouldn't really call it laggy.
It seems more like it takes away a bit of the "hit" when boost comes on but I don't really find myself waiting for the turbo to spool ever. It makes power delivery more linear, which is something I would rather have then that hard hit of torque that tends to upset the chassis under corner exit.
I think if I build another manifold though, I'll be using stepped primaries in the 18"-20" length range.
This guy is a liar.
I never found myself waiting for the turbo to spool while driving. But watching an in-car video of my car at an auto-x I am definitely leaving a lot on the table with the response I'm getting on the larger runners.
A new manifold with smaller runners is definitely on the to-do list for this winter. Possibly some TME9+ turbo upgrade action too.
Old Oct 5, 2010 | 03:18 PM
  #372
06MREvo's Avatar
Nice results...Ill be testing my MAP ported stocker against the ToxicFab manifold very soon...
Old Oct 5, 2010 | 05:58 PM
  #373
wshihdnevo's Avatar
This guy is a liar.
What exhaust manifold are you running if you dont mind me asking?
Old Oct 5, 2010 | 06:08 PM
  #374
R/TErnie's Avatar
Full-Race uses sch40 fyi.
Old Oct 5, 2010 | 06:33 PM
  #375
compscibOi's Avatar
Stock turbo record was run on a Buschur ported and coated stock mani.
Any other questions?
