The "Bite" has a new toy to play with 6765 AKA 950R!!!
I would also mod the AMS manifold for a 44mm wg and use a .82 vband turbine. Thats what I put on a 2.4L 4g64 and it should be a beast once it is all done. It previously made 603whp on an SC6152E so the 6262R should bump it up a little.
Sorry off topic. How is your 4G64 holding up. Any head gasket issues?
GAME OVER is the effect I'm looking for
No issues here minimal my car sees is 42psi no problems yet except for a few oxygen sensor I burned up with the C-16.
P.S Ohhh yea and a few turbo's I blew up because they couldn't take the abuse
Quick Pull on wastegate pressure, this thing sounds crazy with the billet wheel...
http://s175.photobucket.com/albums/w...tegatepull.flv
You got it , I think also I would make better with a 6262 and 82. a/r for sure it will unleash the hidden power that's missing, I'm going to switch my AMS set up very soon and going with something else that 63. back housing is not cutting it but im very limited with the AMS kit.
Just did a pull past two impalas ?? lol. Brave man very brave.
also just did a 10.6 on a airfield with zero grip and full weight could only manage 11.2 with the ams kit
I had the same problem as you as i had an AMS 37r which i feel the wastegate is to small for switched to a full race manifolid and bought a 6765 from mike at AWD and the differance is night and day so much more control over the boost i ordered a .63 ex by mistake but its all good as it spools great and made 780+ with std T/B
