The "Bite" has a new toy to play with 6765 AKA 950R!!!
Not much would have been done to change VE, so he would still need to run close to the same boost levels for similar power.
With the bigger compressor, and bigger hotside, I am sure it will make the same power at much less boost pressure, and a good deal more with the wick turned up.
you have to keep in mind sharkbite is running a 2.3 he cant rev the turbo out as high as AMS did on their test. The 950R seems to need to rev out to atleast 9500 to see good power
that would be incorrect. Most of the 8-9 second cars shift between 8-8.5K and hold 4th to 9.5k......the reason a stroker doesn't work well for drag is you can't hold 4th (8500rpm redline) and that is the only reason.Everyone has run faster with a 6265 then a 6765, so far.
To at least 9500rpm
. But never the less its safe. No C16 tune yet, I cant afford to ball out like you!
