evo8 newb problems
Old Mar 3, 2009 | 01:32 PM
  #31
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
idk to me it just sounds like ur running a bit rich. blue smoke usually is burning oil from what i kno. black is rich, white is antifreeze.
Old Mar 3, 2009 | 01:40 PM
  #32
justa4banger's Avatar
if i was you i would get ur tuned checked out......could be running really rich....whats your gas milage like??
and for sparkplugs i would get the ngk bpr8es and gap them to .023....let us know if this helps...
Old Mar 3, 2009 | 03:02 PM
  #33
GEVOVIII's Avatar
Well I ordered the plugs and will be here tomarrow noone had em in stock nearby. Running 23lbs of boost I get 250miles to tank.. That's consistant.. Im gonna see how things r after the spark plugs and im gonna hit up my boy that tuned the whip see what he say or can figure out
Old Mar 3, 2009 | 06:57 PM
  #34
Evo8luva's Avatar
Originally Posted by GrzesieKEvo8
whats CEL? youre scarying me lol
Check Engine Light, If you did your compression test by unplugging the Cam and Crank sensors, instead of unplugging the injectors, it throws a code for the crank/cam sensor, but doesnt matter. you plug them back in, reset the ecu and your good to go.
Old Mar 3, 2009 | 07:36 PM
  #35
barneyb's Avatar
Maybe a little rich but otherwise - normal.
Old Mar 4, 2009 | 05:12 AM
  #36
GEVOVIII's Avatar
Does weather matter..it was cold around 20s or less and the car was only running for like 15 minutes...
Old Mar 4, 2009 | 05:19 AM
  #37
brokeazzlos's Avatar
I would make sure you intercooler pipes are all nice and tight(no leaks)
and get your car tuned
Old Mar 4, 2009 | 06:41 AM
  #38
GEVOVIII's Avatar
will do..thanx everyone..
Old Mar 4, 2009 | 09:29 AM
  #39
GEVOVIII's Avatar
just checked the turbo for play and its perfectly fine no movement vertically or horizontally.. up n down in n out. im getting the plugs later ill see how it goes. if it doesnt fix the problem ill check with the flash an maybe somehow im running rich .. but it wouldnt make sense since i ran this car with this flash for over a year now and it never gave me problems
Old Mar 4, 2009 | 09:33 AM
  #40
smokedmustang's Avatar
I suspect a boost leak somewhere. Get a Boost Pressure tester, or send me your address, I will give you mine (Home depot special, but it works perfect). Do this test Next: REMOVE the negative terminal on the battery. (LEAVE IT DISCONNECTED for 10 minutes). Re-connect battery, START THE CAR WITHOUT TOUCHING THE GAS PEDAL, and LET IT IDLE 10 minutes!!! That resets computer (wont ruin your tune) and go for a ride, stomp on the gas to see if smoke is still there. If it is, I suspect a boost leak!!!!!!!!!!!!!
Old Mar 4, 2009 | 05:48 PM
  #41
GEVOVIII's Avatar
changed spark plugs and wires and the problem is gone.. i noticed one of the wires was ****ed up inside the boot.. the aluminum peice inside the boot that goes on the top of spark plug was loose and disconnected from the boot. so im asumming loose connection in the spark plug wire made a bad connection .. thanx everyone for the help and all the advice.. your guys are cool in my book! cheers!
jorge mr
22
Nov 9, 2018 05:05 AM
Tommyfacekicker
70
May 20, 2017 09:56 PM
cerealkeller
Sep 7, 2016 04:50 AM
SeahawksOilers
Apr 26, 2014 12:40 PM
WangMan
Lancer Troubleshooting
Sep 30, 2011 05:42 AM
