Need Help on what to do about dump/dp exhaust leak
Old Mar 25, 2009 | 04:58 AM
jhanksevo's Avatar
Hey guys I have the EPM 02 dump and a megan downpipe and while doing my clutch last weekend I notice a lot of soot on the dump pipe, looked like it was coming from where the downpipe and o2 dump pipe mate. I have a stock donut gasket installed and the bolts supplied with the dump installed
My question is what bolts/gaskets do people use to prevent this leak? and Where can I get it from
Thanks
Old Mar 25, 2009 | 07:08 AM
Evo9Kid's Avatar
no idea but i have the same down pipe and 02 so let me know what u find out... i havn't put mine on yet tho
Old Mar 25, 2009 | 07:15 AM
TeStUdO's Avatar
Use the stock down pipe bolts, the ones with the springs on them.
Old Mar 25, 2009 | 07:47 AM
xmaciek82x's Avatar
The EPM o2 Dump is threads for bigger bolts then the stock one. I just went to HD and got regular bolts. Is your donut gasket damaged?
Old Mar 25, 2009 | 07:59 AM
Kracka's Avatar
Try a new donut gasket. That's pretty dumb you can't reuse the stock spring bolts.
Old Mar 25, 2009 | 08:33 AM
TouringBubble's Avatar
My donut gasket was damaged and caused the same leak ... a pretty bad one. I had cranked down my DP on my old O2 housing and that's what damaged it. When I installed the EPM, the leak showed up. Swapping the donut gasket solved the issue.
Old Mar 25, 2009 | 12:05 PM
jhanksevo's Avatar
thanks much everybody now i need a donut gasket any 4 sale
Old Apr 11, 2009 | 03:10 PM
jhanksevo's Avatar
update I installed a new oem gasket and im still leaking. Im running out of ideas any help. The area the leak is coming from is near the donut gaskt
Old Apr 11, 2009 | 04:07 PM
evovin's Avatar
Fighters Garage uses a high temp gasket material. Call them on monday.
GL bro!
Old Apr 11, 2009 | 04:33 PM
jhanksevo's Avatar
thanks vin
Old Apr 11, 2009 | 05:54 PM
Vibrant's Avatar
I had this same problem after my new clutch install. I just used hi-temp gasket maker around the outside of the donut. Problem solved.
Old Apr 12, 2009 | 05:27 PM
jhanksevo's Avatar
will have to try that. I did notice that the stock donut gasket did not seat properly. What gasket do people use with the megan racing downpipes
VRSF Tiago
EvoX 'For Sale' External Engine / Power
169
May 5, 2019 02:35 PM
jk_evo8
May 7, 2016 08:44 PM
evo9powerr
14
Nov 5, 2014 09:27 AM
IX_MR
Aug 31, 2014 12:56 AM
Benja
Nov 14, 2010 03:03 PM
