Throw-Out Bearing wont Release
Old Mar 31, 2009 | 07:05 PM
prockish_03evo's Avatar
Angry Throw-Out Bearing wont Release
I am trying to release my exedy twin clutch from the tob and it will not release. I have done a few other evo clutches with no problem but NOT this one. It is really being a PITA! I got a 3 foot prybar to fit but still will not release.
PS: The reason why i am taking the clutch off is because when i came to a stop the car would barely shift into 1st gear (Really Hard and Notchy) and trouble shifting below 3000rpm. Could the throw out bearing break or something? And if anyone else has had this problem how did you get it to release?
Thanks for your input
Old Mar 31, 2009 | 07:14 PM
Bggstin's Avatar
You could remove the pressure plate from the assembly by the allen keys if you cant get the TOB clip off. Then pop the tranny off as normal and the pressure plate will be hanging on the shaft with the clip and you can pop it off after. I've had to do this before.
Old Mar 31, 2009 | 07:33 PM
JKD's Avatar
JKD
The key to separating the TOB from the pressure plate is to rotate a screwdriver between the two. I have tried to put muscle into it and pry extremely hard with no luck. I found the best solution is to take the widest flathead screw driver as possible and turn it. This will separate them.
Old Mar 31, 2009 | 08:57 PM
srtboostin22's Avatar
Lonnie @Lascuola in my area had a HELL of a time getting mine un-done.. he has done several and he said my car was the most pita.. what we wound up doing was going through the excess hole and undoing all 7 bolts that hold the flywheel to the clutch assembly.. that way when you pop the tranny off.. the flywheel just comes tumbling down and you can try and release the tob from the ground..
Old Mar 31, 2009 | 09:02 PM
Bggstin's Avatar
+1 What I said...this I've found is easier most of the time.
Old Mar 31, 2009 | 09:04 PM
P-ROY's Avatar
I had to cut mine off with a cutting wheel!
Old Mar 31, 2009 | 10:19 PM
magyar86's Avatar
i recently changed a clutch on a 2000 eclipse witch has the same style clip and it wouldnt pop off for anything, i ended up having to remove the bolts that hold the pressure plate to the flywheel as metioned above by going through the clutch fork opening. the last person that installed the clutch put the clutch disk in backwards ("fatter" part of disk was toward flywheel) and it blew up causing everything to get bent up and jamed so even after getting the tranny out the dang thing still wouldnt release, so i just used a dremel and cut it off.
Old Mar 31, 2009 | 10:23 PM
newimportowner's Avatar
Same thing happened to me. we had a set of shallow swivel snap-on sockets that were able to get in and seperate the clutch from pressure plate through the shift linkage opening. a real pain in the ***. we replaced a stcok clutch, but didnt release the throw out bearing prior to pulling the tranny off, it locked it on for good.
Old Apr 1, 2009 | 07:19 AM
Lilredbox's Avatar
Yes. If you're unable to get it by twisting the flathead screwdriver, this is your next option. Not hard IMO.
Old Apr 1, 2009 | 10:00 AM
mrtalon20's Avatar
I just ran into this problem with my act I had to remove the bolts to get the tranny out.
Old Apr 1, 2009 | 10:40 AM
spyderx's Avatar
I have similiar issue w/ my Exedy twins. Going into 1st gear is PITA! Hard and Notchy. Got better w/ Amsoil fluid change. What causes this ???
Old Apr 1, 2009 | 12:05 PM
DIDYSIS's Avatar
Dont try anything else, just keep working at it, you will get it, also push the tranny back on a litle so its not pulling on it to hard, its possible, I have done it a few times and finally think its a little easier.
[QUOTE=JKD; I found the best solution is to take the widest flathead screw driver as possible and turn it. This will separate them.[/QUOTE]
Old Apr 2, 2009 | 10:24 AM
ok guys thanks for the input i will have to try unbolting the 7 bolts and just try and get the tranny off. When i get the tranny off and if i still cant release it what would you cut on the TOB to release it?
MnchMnchV84Lnch
Nov 11, 2013 07:02 PM
2003Evo900hp
Oct 7, 2011 11:52 AM
fanbelted
Jul 3, 2009 08:23 AM
ChrisMcP05
Dec 26, 2008 07:56 PM
hillbilly8R
Aug 24, 2008 12:45 AM
