New clutch blues
Old Apr 11, 2009 | 09:52 AM
6thfloor's Avatar
New clutch blues
So I had my dealership, which is now only a service department, install a new clutch on my evo 9 mr. And I drove nice and easy for 500 miles and every thing seemed fine. Now when I try hard first to second shifts it grinds. And today I went to leave my house and I can't get it in gear, any gear. I had to park outside last night and it got down to freezing.
Any time I bring my RPMs up over say 3500 and push in the clutch the RPMS don't fall they just hang at the RPM slowly dropping
I will be taking it in to get serviced again.
Anyone know whats going on with my car?
btw it is stock.
Old Apr 11, 2009 | 10:17 AM
jxs1984's Avatar
do you know which fluid they used for your 6-speed transmission? the rpm slowly dropping is normal.
Old Apr 12, 2009 | 04:50 AM
6thfloor's Avatar
No
Old Apr 12, 2009 | 04:59 AM
sikwititevo9's Avatar
you should take it back and let them know that something is wrong with the install. i would go down there and raise hell over it.
Old Apr 12, 2009 | 06:12 AM
JKD's Avatar
JKD
Adjusting your clutch pedal will cure your problems. Try turning the master cylinder rod so your pedal comes outwards.
Old Apr 12, 2009 | 08:21 AM
6thfloor's Avatar
Thanks. I will talk to them on monday.
Old Apr 12, 2009 | 09:56 AM
FX11's Avatar
do this
put your car in gear when the car is off
turn the key
see if you can start to get moving
and then try shifting once u get it moving
Old Apr 12, 2009 | 01:02 PM
ev0lution9's Avatar
every evo has a little throttle hang when you shift dont worry about that the thing with getting in the gears idk check the fluid they used or adjust the pedal like the other people said
Old Apr 12, 2009 | 02:56 PM
6thfloor's Avatar
It goes in gear after it is completely warm.
Now today i took it out and the clutch did not come back up and i did not realize it
and when i started slowing down and down shifting thats when I realized some thing was wrong, I could also smell burnt new clutch. So i pulled the pedle up with my foot and now the clutch seems to work fine except for a clicking sound and an incredably long through.
texaspete108
Lancer Troubleshooting
Nov 1, 2011 08:10 PM
asahlot
10
Aug 20, 2010 06:20 PM
amsevokid
Apr 19, 2010 07:17 PM
cybertrax
Aug 28, 2009 12:47 PM
bluej20
11
Dec 18, 2007 09:46 PM
