Are some cams knockier than others?
Old May 13, 2009 | 04:48 PM
racer135's Avatar
I have heard that some people have had issues with some cams being very prone to knock. Some people say their cams are knocky.
For the ones that have have this issues was it really the cams? Or was it something else like installation, lifters, etc?
Old May 13, 2009 | 06:42 PM
crcain's Avatar
Do you mean real knock or false knock?
Old May 13, 2009 | 06:57 PM
racer135's Avatar
I guess any of the two. Knock that pulls timing in general.
Old May 14, 2009 | 08:12 AM
crcain's Avatar
In terms of false knock, it's thought that sometimes valvetrain noise, like lifter tap, etc might contribute to false knock. In this case, a cam with high lift and a steep ramp rate might trigger false knock more than another more mild cam. But there is no evidence to support this, and it is uncommon I believe.
In terms of real knock, yes a cam will effect the VE of the motor, which will effect fueling and probably to a lesser degree timing. So yes you might change a cam and then knock. But to answer your question, nobody talks about cams in terms of their ability to resist or create knock. The cam's job is to move the valves in a motion which allows the most air to be ingested, independant of knock/timing.
TwistedEvo8
26
Aug 7, 2016 06:48 PM
ctfpevoVIII
29
Jun 5, 2013 07:34 AM
corbzin
Jun 12, 2012 08:28 PM
damianhindley
16
Jan 11, 2011 06:59 PM
Gsxfury
Sep 20, 2005 10:37 PM
