crank pulley removal???
Old May 14, 2009 | 04:16 PM
mr 2.3 evo's Avatar
help im in the middle of doing some bottom end work on my car but i dont have the tool to get the crank pulley off. i was wondering what other solutions or tools i could use if anyone has done this before?
Old May 14, 2009 | 04:26 PM
wevo1985's Avatar
take the 4 bolts out, use some rust penitrate on it and tap each side with a hammer(be careful not to break it) and it should come loose.
Old May 14, 2009 | 06:48 PM
mr 2.3 evo's Avatar
thanks for your help but i got that one off i need the timing belt crank pulley off thecog pulley.
Old May 14, 2009 | 08:05 PM
TIBOevo's Avatar
maybe if you put it in gear and let the tires touch itll keep the crank from spinning while you turn the bolt. is the motor out of the car?.
Old May 14, 2009 | 08:22 PM
mr 2.3 evo's Avatar
motor is out and on the engine stand
Old May 14, 2009 | 08:24 PM
biggie5252's Avatar
I tried that and the motor still turned against the clutch (act). We even took a long extension out past the wheel well and broke the extension. The only way I could get it off was with a pneumatic impact gun, a big one, and it still took a little bit, but it finally came. There's also a tool to hold crank in place.
Old May 14, 2009 | 08:31 PM
PVD04's Avatar
This'll be tough. My 250 ft-lb impact wrench didn't break mine loose. I had to jump on a 3 foot breaker bar.
Old May 14, 2009 | 08:37 PM
EVOLVEU's Avatar
Damn^^^
Old May 14, 2009 | 10:09 PM
jid2's Avatar
^^^^ Word.
This guy (original poster) is reliving my build thread. Read this. There's more fun to come at this rate...
https://www.evolutionm.net/forums/ev...3076build.html
I have a really good impact gun. The crank bolt laughed at it. I used a bar I custom built for the flywheel, and a pipe on a breaker bar. See below.
Old May 14, 2009 | 11:34 PM
Werd's Avatar
I'm sure you can rent a pulley kit from advanced auto parts or someplace like it. And to keep the crank from turning, just have someone hold it with a flathead against the bar of the engine stand. Assuming I'm understanding your problem right...
Old May 15, 2009 | 05:53 AM
mr 2.3 evo's Avatar
i have all the bolts out of the pulley. when i looked it up on the net how to get it off there is a tool that is use for it. but i dont have that tool...... ill take pics of where im at so there is no confusion
Old May 15, 2009 | 06:14 AM
batty200's Avatar
All I have ever doen is put the bolts in the crank damper pulley with about 1/4 in of slack and use the factory crank damper to hold onto and use it like a small slide hammer and just pull it out and let it pull the crank gear off. You do need the main crank bolt out to do this though.
Old May 15, 2009 | 03:21 PM
mr 2.3 evo's Avatar
thanks you for your help i have the main bolt out and ill try to do it with my slide hammer
diego88
Evo X How Tos / Installations
Jul 11, 2017 10:31 PM
Demon_ni2
Lancer Engine Tech
61
Apr 16, 2013 10:13 AM
RSGuy
12
Oct 15, 2012 03:37 AM
sti killer 187
Sep 23, 2006 06:03 AM
03lancOZ
Lancer Engine Tech
11
Jul 31, 2006 02:39 AM
