My Battery Relocation
Old Dec 20, 2010 | 01:34 PM
  #106
Zivman's Avatar
Originally Posted by cij911
More strands = better....That said, I suspect I should have a 0 awg wire to the back....For now I will just keep the stock battery in the stock location...
I ran 0 awg wire for my relocation. bought this
Old Dec 20, 2010 | 01:46 PM
  #107
cij911's Avatar
Looks nice...Thanks for posting.
Old Jun 2, 2011 | 12:10 PM
  #108
mission664's Avatar
where do you hook up the positive wire under the hood to run into the trunk? the positive wire under the hood has three different wires connected to it, are two of those not needed? and what do you do with the ground wire under the hood once the battery is relocated?
Old Jun 2, 2011 | 12:22 PM
  #109
CO_VR4's Avatar
Originally Posted by binh
that tray looks great...is that something you can order off the internet or was that custom made?
As a digression, these (CNC'd Optima battery) trays look very well made, but probably would not pass any drag racing or road racing tech inspection...
Old Jun 6, 2011 | 06:52 AM
  #110
Locdizzel's Avatar
I connected all 3 positive wires and put them in a small plastic box, for the positive I connected a wire I had from a ground wire kit I had and connected to the bolt in the middle of the strut bar
Old Jun 16, 2011 | 07:32 PM
  #111
Protostar1's Avatar
Hola,
I am planning to relocate my battery this summer as I need to improve the winter reliability of my car (Odyssey battery doesn't like to operate below 32F...). I would like to reuse the stock battery and was considering the Taylor Relocation kit because it looks pretty sexy. In terms of a non custom kit I haven't seen anything in this thread to beat it but would welcome advice on other kits to look at.
I have a couple questions:
- Does the included 192in (16ft) stretch from the stock pickup on the left front side of the car all the way to the right rear in the trunk (or at least to a fuse, then to the battery...)?
- For those have used this kit, what parts are included and what terminals, bolts, etc do you need to purchase to complete this kit?
Those are my only questions... for now... Thanks guys!
Old Jun 16, 2011 | 08:12 PM
  #112
Israel's Avatar
I see some people using a battery box and some aren't. If I buy a sealed battery, am I going to he okay at the track without a box?
Old Jun 17, 2011 | 12:22 AM
  #113
bronto11588's Avatar
I can't guarantee it but where I am it wont be legal without the box. Maybe if you found a way to secure it. Also for a battery relocation you need a cutoff switch for it to be track legal
Old Jun 17, 2011 | 08:14 AM
  #114
Protostar1's Avatar
Where does the cutoff have to be located? Could you put it right next to the 150amp fuse in the trunk?
Anyone able to comment on 16' of 1g cable being enough to relocated to the passenger side of the trunk?
Old Jun 17, 2011 | 09:28 AM
  #115
Israel's Avatar
I would have it bolted down. Even if the track didn't require it, I don't want my battery tumbling around back there.
Old Jun 17, 2011 | 09:39 AM
  #116
dastallion951's Avatar
im runnin an optima red top with the taylor relocation kit, now one thing i did was since the battery requires the use of about 10 ft of the wiring, i just went a group size bigger, due to loss of amps and volts through the gauge wire thats in the kit. As far as cutoff switch, my last track event at battle of imports at fontana speedway in cali, they said next time i cant run until i have a cutoff switch installed most people install the cutoff in either the back bumper, or on the dash somewhere i just gotta consider where to install mine..
Old Jun 17, 2011 | 09:44 AM
  #117
Israel's Avatar
If I were to put a kill switch on the bumper, I'd try and put it under the license plate and then I'd pull the plate at the track.
Old Jun 17, 2011 | 11:54 AM
  #118
jcl's Avatar
jcl
Local tracks it has to be available if the car cant be opened. Front or rear bumper are common places but you can probably get pretty creative with it and put it somewhere out of place as long as you mark the location for officials to find it.
Old Jun 17, 2011 | 12:02 PM
  #119
X91EVO's Avatar
Registered User
knukonceptz is great wire I also bought mine from there.
fyi to everyone the battery cable should be ran around the driver side fender inning to do a proper job
Old Jun 17, 2011 | 12:07 PM
  #120
Protostar1's Avatar
Why not through the glovebox firewall and under the door trim to the trunk?
