My Battery Relocation
Old Jun 17, 2011 | 12:09 PM
  #121
Protostar1's Avatar
Originally Posted by jcl
Local tracks it has to be available if the car cant be opened. Front or rear bumper are common places but you can probably get pretty creative with it and put it somewhere out of place as long as you mark the location for officials to find it.
So then it would be a no go on a previous post's recommendation to put it on the dash? I have another car with a remote battery and the cutoff switch is between the seats. Though the car has no top...
Old Jun 17, 2011 | 07:52 PM
  #122
Protostar1's Avatar
Also... what do you guys use to crimp a 1 or 0 gauge wire terminal to the wire? Or are the terminals in the kits a bolt or set screw style?
Old Jun 17, 2011 | 08:36 PM
  #123
Israel's Avatar
In the past, I've used welding cable and the terminals made for welding cable. What I'll do is heat up the terminal end with a propane torch until I can melt a small pool of solder into it, then I push the cable into it.
Old Jun 17, 2011 | 08:39 PM
  #124
Israel's Avatar
If you want to crimp, there are tools out there like this one: http://www.mechanicstoolsandbits.com...f7c5942f1cd932
Old Jun 18, 2011 | 12:17 AM
  #125
bronto11588's Avatar
My cutoff is located behind the driver side tail light because it has to be accessible from outside the car I just pull the light each time only 2 screws ill post up a pic of my relocation later
Old Jun 18, 2011 | 06:12 AM
  #126
phrequenc's Avatar
on my list
Old Jun 18, 2011 | 01:18 PM
  #127
X91EVO's Avatar
Registered User
Why not through the glovebox firewall and under the door trim to the trunk?
if you want wire all over your engine bay and interior trim that barely fits then thats fine
Old Jun 18, 2011 | 04:14 PM
  #128
tscompusa2's Avatar
then the connection is hidden under the air intake pipe
but.. if you really want a super clean wire tuck look, id advise to run it under the car so you can rerun the stock harness down towards where the steering rack is so its ran behind everything and out of visual sight no matter what.
for now im good where mine is ran, but the way i have it pictured where it runs through the fender area and out where the fuse box area is, you have no choice but to have a big harness running across the top of your transmission. (its like this stock also btw)
Old Jun 28, 2011 | 09:01 AM
  #129
Protostar1's Avatar
I am ready to bite the bullet on this (just the relocate kit and fuse, I will worry about the cutoff later as I do not plan on racing/ tracking anymore this year). I am going with the Taylor kit from Summit. There are a ton of versions, which have you guys purchased? Did it come with a precrimped negative lead? Thanks!
Old Jun 28, 2011 | 10:09 AM
  #130
06MREvo's Avatar
I really like that kill switch setup, very nice...But don't most tracks require your tail lights to be on/working to race? So wouldn't you need to have both tail lights in or no??
Old Jun 28, 2011 | 04:02 PM
  #131
Protostar1's Avatar
FWIW for those looking at Taylor Kits to use with the stock battery, you need the standard relocation kit, you can't use the 200 or 300 series boxes as they are too small for the stock Mitsubishi battery. I went with the standard 1awg setup and a Tsunami 180amp breaker.
Old Jun 28, 2011 | 10:11 PM
  #132
TommiM's Avatar
I have started another project on the evo as part of the rebuild process. One thing I notice with many guys who relocate their batteries, and is even in the how to, was just to cover up the fuse box that was over the oem pos cable.
Wanting something more clean I started a project to improve on my battery relocation and am taking lots of pics to maybe give you guys ideas, and maybe get some feedback/input/criticism.
I am about 60% finished and will start a new thread for it. One thing I did was upgrade the 2 gauge power cable to a higher quality 0 gauge cable. I also am relocating the battery pos fuse box along with cleaning up some of the wiring. There is a redundant amount of wiring that was needed when the battery was in the stock location but now that my battery is relocated to the trunk it can be cleaned up.
Fwiw, The 15ft of Stinger Pro series 0 gauge was not much heavier than the 15ft. of 2 gauge I orignially bought from Napa. The Napa stuff did its job but I was not happy with how unbendable that stuff was.
Old Jun 29, 2011 | 12:17 AM
  #133
Don't know about road races but 1/4 mile only requires 1working brake/taillight to be in regs
projektevo9
For Sale - Part Outs
55
Aug 14, 2018 03:24 PM
Mr.X
Jun 17, 2015 04:28 PM
03chi-town0Z
41
Jan 2, 2014 05:04 PM
clubEVO93
Midwest Region
Nov 23, 2011 03:03 PM
avo3vom
Apr 8, 2011 05:15 PM
