My Battery Relocation
Old Dec 18, 2010 | 10:39 AM
  #91
cij911's Avatar
Seems like a ton of work (with room for problems) for a street car, not to mention just another large object to take up the trunk . I guess this is the only solution for folks wanting a short route UICP and don't want to worry about the small battery going dead....
I have been holding off -- I want to install my BR UICP, but don't want to move the battery. My plan was to just get a small battery kit. These threads always throw a twist in my plans ....Maybe I should reconsider moving the battery to the trunk.
Old Dec 18, 2010 | 12:49 PM
  #92
n2oiroc's Avatar
Its not a lot of work and there arent problems unless you hack your way thru it.
Old Dec 18, 2010 | 01:37 PM
  #93
wizzo 8's Avatar
Its basically the same procedure as wiring up an amp in the trunk except its a battery not an amp. So if you have every wired in an amp before it should be easy for you.
Old Dec 18, 2010 | 02:01 PM
  #94
tscompusa2's Avatar
ya its extremely easy. ill try to dig up where i ran my wires (behind the fender well covers and through the harness grommet) theres another battery relocation thread on this forum where i posted my pics.
Old Dec 18, 2010 | 02:03 PM
  #95
tscompusa2's Avatar
https://www.evolutionm.net/forums/ev...routing-2.html
Old Dec 18, 2010 | 02:05 PM
  #96
tscompusa2's Avatar
also.. i have improved drivability from going from a mini to a big battery.. the car felt a lot smoother and a lot funner to drive vs the odyssey battery i had.. my battery was on its last leg also tho.. and the reason i didnt mount battery on passenger side is because i was going for a straight shot path for the positive wire.
Old Dec 18, 2010 | 07:02 PM
  #97
TommiM's Avatar
Its pretty easy actually. I routed the positive cable from the engine bay through the pass grommet behind the glovebox, underneath the pass door sill/floor, through the pass rear door sill/floor, through the bottom of the rear seat, into the trunk. The evo interior pieces come off super easy. You can chose to route it how you wish but dont let it scare you, its not that hard to do with a little bit of patience.
Old Dec 18, 2010 | 08:01 PM
  #98
BuiltS13's Avatar
To the OP, did you not have enough cable to hide everything a little better? Pretty clean otherwise
Old Dec 18, 2010 | 10:44 PM
  #99
tscompusa2's Avatar
i would have done that, it also allows you more room to hide the cable also in engine bay, but i have that entire grommet stuffed with vacuum lines and other stuff already
Old Dec 19, 2010 | 07:33 AM
  #100
cij911's Avatar
I already have a cable (iirc 4awg) running to the back trunk for an amp I installed....I wonder if I could just use that ? Or do I need to run 0awg ?
Old Dec 19, 2010 | 08:54 AM
  #101
wizzo 8's Avatar
4awg is not enough. I think 2awg at the smallest
Old Dec 19, 2010 | 10:24 AM
  #102
BuiltS13's Avatar
I'm pretty sure that's not the type of wire you use either, has wayy too many strands of wire inside. I tried it in highshool and my car wouldnt fire half the time.
Old Dec 19, 2010 | 10:26 AM
  #103
211Ratsbud's Avatar
I've used 4ga for a while now . using an optima red top. I'd like to upgrade when time permits. how is everyone getting 02 or 00 awg thru the firewall ?
Old Dec 19, 2010 | 11:00 AM
  #104
cij911's Avatar
More strands = better....That said, I suspect I should have a 0 awg wire to the back....For now I will just keep the stock battery in the stock location...
Old Dec 20, 2010 | 01:29 PM
  #105
binh's Avatar
What size/model number optimas are you guys using? I'm ordering today would like to know...
