My Battery Relocation
Old Dec 7, 2010 | 11:45 AM
  #76
Dragracer187's Avatar
My battery relocation
  #77
n2oiroc's Avatar
Originally Posted by CarWhore
Hey, on that Tsunami CBF180 circuit breaker, do you just insert the stripped wire into those inputs or do they need a terminal attached to the ends first?
you strip it, insert the bare wire and tighten the set screw.
Old Dec 7, 2010 | 11:46 AM
  #78
CarWhore's Avatar
Thanks!
Old Dec 7, 2010 | 12:11 PM
  #79
Grey Razor's Avatar
Some pics of my completed relocation:
...now I can finally add my new ETS IC piping (short route) and intake.
Old Dec 7, 2010 | 04:01 PM
  #80
avo3vom's Avatar
Originally Posted by Chutney
So, basically you guys just ran the positive wire from the trunk to the stock distribution block under the hood and then installed the fuse in the trunk right after the positive terminal off the battery? I just want to make sure before I go cutting the wire.
Correct, only cutting involved was the positive wire to the breaker in the trunk. All stock wire remain intact.
Old Dec 7, 2010 | 05:57 PM
  #81
binh's Avatar
that tray looks great...is that something you can order off the internet or was that custom made?
Old Dec 8, 2010 | 06:05 AM
  #82
Grey Razor's Avatar
I've seen those trays around. Here is one place that I've seen them: http://67.199.57.160/store/pc/viewPr...9&idcategory=6
Old Dec 8, 2010 | 08:23 AM
  #83
xmaciek82x's Avatar
Yup, I'm pretty sure that is where I got my.
Old Dec 8, 2010 | 09:55 AM
  #84
I got it from e-bay, seller optimatrays.
Old Dec 17, 2010 | 06:25 AM
  #85
binh's Avatar
What size/model number optimas are you guys using? I'm ordering today would like to know...
Old Dec 17, 2010 | 07:10 AM
  #86
wizzo 8's Avatar
I may have to do this and get rid of my mini battery. For the winter months I have a jumper box in my trunk hooked up to the power wire that goes to my amp. Works good for now but its not permanent. Pretty getto also.
Old Dec 17, 2010 | 08:47 AM
  #87
R/TErnie's Avatar
FYI... for those of you who are relocating your battery... put the battery on the passenger side of the car. I've corner weighted enough of these cars to know the LF is the heaviest and the RR is the lightest.
Old Dec 17, 2010 | 06:07 PM
  #88
TommiM's Avatar
Or as far forward, close to middle of the car as possible to keep the weight closer to the center of the car. I put my trunk mounted mini battery between the shock towers on the floor of the trunk.
Old Dec 17, 2010 | 07:05 PM
  #89
R/TErnie's Avatar
yeah... otherwise you'll have a nice yaw moment
Old Dec 18, 2010 | 10:06 AM
  #90
JDMS60R's Avatar
Nice install, looks like you reused the stock battery and tie down?, I'm assuming that fits with the summit box.
