Question from a newer owner
Old May 28, 2009 | 12:56 PM
drop24's Avatar
I noticed my car has developed a very slight lag or roughness in throttle response when the car isn't fully warmed up. Is this normal? Or could it be any indication of abuse by a previous owner? Could the clutch perhaps be at fault? Does it need a while to warm up to hold on tight? Maybe I'm being over cautious. 32k on the car.
Old May 28, 2009 | 12:57 PM
linuxman51's Avatar
thats normal. If you're feeling brave, the fix is documented in the ecuflash forum, you turn off the cold start timing retard feature.
Boostfiend's Avatar
Change the spark plugs, it worked wonders for my car.
drop24's Avatar
Note: I never boost it unless it's fully up to operating temperature. I might try cleaning the air filter to see if that makes a difference.
Old May 28, 2009 | 12:58 PM
drop24's Avatar
linuxman, what is the purpose of the cold start timing retarding. Just want to know before I disable something.
Old May 28, 2009 | 01:07 PM
drop24's Avatar
Did some reading on cold start driving the Evo. It definitely seems like other cars are the same as mine. I probably just didn't experience this before because I always let it warm up fully before driving. Thanks for the help. It's a relief.
Old May 28, 2009 | 01:08 PM
RoadSpike's Avatar
Far as i know the cold start timing feature is purely for emissions to quickly heat up the cat.
Old May 28, 2009 | 01:45 PM
stock_evoIX's Avatar
yes if youre impatient and dont wait for op temp, then the car drives super laggy. I dont boost really until it warms up fully
Old May 28, 2009 | 01:46 PM
drop24's Avatar
Oh, it might be worthwhile to get rid of that feature then. Since my cat is unusually slender and straight :P. I'll do some research.
Old May 28, 2009 | 01:51 PM
jjm4life's Avatar
evos are rough when they are cold. its just the way it is. give yourself another min to let it warm up, or just take it easy on the car until its up to temp. nothing new, esp for us cold weather guys
Old May 28, 2009 | 06:23 PM
ernald711's Avatar
mine was like that... also check ur TB. i had all this build up in there.
evo1008
Nov 25, 2013 10:07 AM
PaulyX
Jul 22, 2013 05:09 PM
DirtyRalli
Mar 15, 2013 01:19 AM
PaperClip
Jan 3, 2012 05:23 PM
Mauricio Evo IV
Jun 9, 2011 08:10 AM
