Is Royal Purple worth the $$$
Old Jun 29, 2009 | 02:55 PM
  #76
Ted B's Avatar
Originally Posted by vmrevo9
they guarantee 15K miles for severe use (turbo, supercharged, towing) applications and 25K miles for n/a cars etc. see if you can run mobil 1 to that limit.
FYI - Mobil 1 makes a similar guarantee.
Anyone is welcome to see how long they can go between oil changes, but I won't be joining that experiment. Good luck.
Old Jun 29, 2009 | 03:01 PM
  #77
apagan01's Avatar
comeone TED dont's be affraid, we can use that brand new engine of yours
it's actualy 17,000 for severe
and by the way the test has been done hundreds of times by many AMSOIL gear heads around the country, using our oil analysis lab
Mobil makes a great product as well
Old Jun 29, 2009 | 03:04 PM
  #78
Ted B's Avatar
It isn't so much about the oil itself, but about the submicron particulate, moisture accumulation, oil fouling with alcohol, and other non-filterable impurities that I prefer to purge from the system every 3k miles.
Amsoil is a fine product, but I'll stick to my 3k change interval.
Old Jun 29, 2009 | 03:14 PM
  #79
LancerEVA06's Avatar
Originally Posted by apagan01
Just a little bit for the ones that are saying get this oil and get that oil,,, you guys make the conclusion by looking at the chart on how much you will spend buying this brand or that brand over the long term
Only problems I see with this is a turbo charged engine shouldn't go further than 3000 miles. Second, if 3,000 is the max, then this chart should be alter to show such. However, Amsoil is great oil, if I'm able to get it easily I'll use it over Mobil 1... but no dealers near by and can't wait for shipping most of the time.
On topic... Royal Purple is good oil, just way too much detergent in it. After 2k miles it's so dirty it needs to be changed.
  #80
apagan01's Avatar
oh believe me iam as picky as you or if not more, myself personally i change my oil at 1700- 2500 k intervals,, i know way overkilled but thats just me,
Ted i think the message is being miss read.
what they are trying to say is that the oil has been designed to run for that period of time, the oil is capable of running 17k without issues,,, however because of the old mentality still being implemented customers still insist in running their oils at the 80' fashion.
high quality oil's like AMSOIL, Mobil or some good synthetics are designed with detergents and additived to where they can resists all the conditions very well,, NOAK testing provides some good data, oils these days hold up to humidity, heat, shear and all the junk that enviroments throw at them, however a very good oil filter is needed to ensure propper filtration.
Old Jun 29, 2009 | 03:19 PM
  #81
apagan01's Avatar
you are saying that a turbo car shold not go over 3k, please provide data that shows that an oil that was ran at 10k for example was not performing any more.
i will dig thrue my pc and try and find some data of some starion'' that ran AMSOIL back in the day at 15k drain intervals with no issues,,,
however you are right, the chart is for normal DD, because 85% of our customers are non turbocharged.
Old Jun 29, 2009 | 03:22 PM
  #82
I'm not saying it wouldn't last... but I wouldn't take it past 3500. Now sure I'd change the oil, and put the old Amsoil with 3000 miles into my girlfriends explorer and let her go 10,000 miles with it... but for peice of mine, I dont take any oil (no matter how the tests look) over 3k in my evo.
Old Jun 29, 2009 | 03:27 PM
  #83
apagan01's Avatar
hey that is understandable.
it just doesnt fell right surpasing 3k on any oil no matter what that manufaturer says,,, however i would hope that we trust the data provided by that manufaturer,, even more if thay are saying that they will garuantee the oil and you system.
Old Jun 29, 2009 | 03:31 PM
  #84
BoostINurI's Avatar
Ummm hmmm i get bored and change my oil every month or so for grins .....I use Mobile from day one....i don't know why that my oil cap say's USE MOBILE ONE ONLY hmmmm weird.
Old Jun 29, 2009 | 04:22 PM
  #85
apagan01's Avatar
your cap says mobil one because mobil 1 pays mitsu to advertise their oils true them,, simple as that.
Old Jun 29, 2009 | 04:30 PM
  #86
javip1986's Avatar
I use purple, and haven't had any problems so far. My car had 40,000 miles on it. But i will like to try other stuff.
Old Jun 29, 2009 | 07:10 PM
  #87
lemmonhead's Avatar
those figures mean squat,we are talking chump change. money really is no issue when everyone is within $200 per 25,000 miles. Shoot even if mine was $400 more every 25,000 it wouldn't change a thing. we are not talking thousands of $$$ here.
Old Jun 29, 2009 | 07:13 PM
  #88
lemmonhead's Avatar
best advise to everyone, use 1 type of oil for 3 oil changes, have it blackstone lab tested every oil change. www.blackstone-labs.com/
then change to another type and do the same test. then repeat back to the original and test again. Evaluate the difference and make a very EDUCATED decision which is the best.
Old Jun 29, 2009 | 08:09 PM
  #89
Yep. Did it with the ES with 3 oils. Like the results of Mobil 1 0W-30 best for that motor
jarek0621
24
Dec 3, 2015 03:26 PM
RA010926
26
Feb 11, 2012 04:52 AM
sktng22
60
Oct 16, 2010 06:03 PM
FartMuffler
May 26, 2006 01:56 PM
04 rs
11
Sep 10, 2005 08:53 PM
